Clutch question??
Old Mar 20, 2008 | 04:35 PM
Truxx1956's Avatar
Truxx1956
Question Clutch question??
Hey guys, I'm a regular on the '48 to '60 site, but I have an '89 model F150 with a 300 6cyl and a M5OD trans. My question is does it have a 10" clutch or an 11"? And if it does have the 10" can I put a 11" in when I change it? I dont have it apart yet, so I havent measured it.
The truck had been run without trans fluid when I got it, and the trans was STUCK. I managed to get it unstuck by jammin on the brakes and not using the clutch. Now I cant downshift from 3rd to 2nd without being completly stoped. This may have a previous problem before the trans was run low on oil? Is it possible that something is just out of time in the trans? Or is this a common problem when the syhchros go out?
Thanks in advance guys!
Old Mar 20, 2008 | 04:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The 1980/89 Ford truck parts catalog shows only one M/T flywheel used 1980/91 on 300's: E0TZ-6375-A.
The parts catalog shows two different clutches: 10 & 11 inch.
Old Mar 20, 2008 | 09:22 PM
Truxx1956's Avatar
Truxx1956
Red face
Thanks Bill, about the clutch part, but do you know about the trans question? And can I just use the bigger clutch without problems?
Thanks!!
