Rough Idle no codes
Old Mar 20, 2008 | 03:04 PM
donniesd's Avatar
donniesd
Rough Idle no codes
I got a check eng Light. Went and had the sparkplugs and Boots changed, all 8 and fuel filter.
Now i am getting a rough idle. But if i put it in neturel, it goes away. But in park or drive it is rough. I am not getting any codes.
Where esle should i start to look.
Old Mar 20, 2008 | 03:06 PM
donniesd's Avatar
donniesd
Forgot to add.
1998 Navigator 4X2 173K Miles.
Been searching. Where is the IAC valve. What is the best way to clean it.
Old Mar 20, 2008 | 03:20 PM
Trucker22's Avatar
Trucker22
Iac
The IAC is on top of the engine---about the easiest thing to work on---it's round---lays horizontal---is usually shiny zinc chromate color---has a wire harness connected to it on the end---and comes off with two small bolts--may be hex---I don't recall
With your kind of mileage---I'd just replace---but I have cleaned em---there is a small gasket---that should be reusable if you clean it.
Old Mar 20, 2008 | 03:31 PM
donniesd's Avatar
donniesd
Originally Posted by Trucker22
I'd just replace
Thanks for the help. I think your right. Cant hurt. They are 50 bucks.
Old Mar 21, 2008 | 10:05 AM
kailor's Avatar
kailor
Yes, do check/clean the IAC valve. This only takes 15 minutes. Also, check all vacuum lines for leaks and hisses.
