Exhaust help
Old Mar 20, 2008 | 02:52 PM
Strester's Avatar
Strester
Exhaust help
What is the best exhaust for 2003 7.3 Excursion? Where to get it? Has anyone just changed the muffler?
Old Mar 21, 2008 | 07:53 AM
kawajockie's Avatar
kawajockie
I also have a 2003X w/7.3.
After LOTS of looking I ordered the silverline FS102409 SS system from MKO power. Give them a call, they can hook you up with a great price.
Why silverline? Great sound, comes with a tip, nice fit and finish.
Lots of folks also like the MBRP system. MKO has those too and from what I can tell will beat everyone prices.
Old Mar 21, 2008 | 07:54 AM
kawajockie's Avatar
kawajockie
Sorry, here are the links
www.mkopower.com
www.silverlineexhaust.com
And for a sound clip go here
http://www.silverlineexhaust.com/SoundVideo/index.html
Old Mar 21, 2008 | 07:56 AM
kawajockie's Avatar
kawajockie
If you are looking for a cheaper route, search the forum for Walker BTM.
This is a muffler you can get from Napa and with a little work you can replace your stock muffler for a little better performance.
I went with the entire 4" system.
Old Mar 26, 2008 | 11:42 AM
Strester's Avatar
Strester
Thanks for the info.
Old Mar 26, 2008 | 12:11 PM
i eat hybrids's Avatar
i eat hybrids
I was thinking about getting a 250 or 350 diesel for a work truck. IF i get the truck, id put an exhaust on it. I have looked at alot of video clips and found the MBRP sounds the best.
Old Mar 27, 2008 | 05:47 PM
02excursion73's Avatar
02excursion73
I did the 4" Magnaflow SS system with the 3.5" downpipe. I have a real bad drone problem at about 1500RPM. I did some research and found this to be a common problem. I installed another Magnaflow muffler in front of the other. The sound is quieter but the drone is worse. I would stay away from Magnaflow for the Excursion for this reason. I am going to try the AeroTurbine Mufflers. The MPRP seams to be the best choice. One note is that I did pick up alot of torque with the new exhaust. Good Luck!
Brian
Herndon, VA
