Bad oil leak
Old Mar 20, 2008 | 10:57 AM
jwhitetail's Avatar
jwhitetail
Question Bad oil leak
Oil is leaking so bad under turbo&compressor in back blowing all over up pipes, big time! Just did all of sudden. O rings or what?
Old Mar 20, 2008 | 11:01 AM
nhill2090's Avatar
nhill2090
are you sure you didnt spring a leak in the HPO system somewhere?
Old Mar 20, 2008 | 11:08 AM
jwhitetail's Avatar
jwhitetail
There's no oil in the front of motor in valley. It's coming from under tubine. and compressor. I just got around to putting the ATS housing on yesterday. And it starting blowing oil out under there after test drive!
Old Mar 20, 2008 | 11:10 AM
nhill2090's Avatar
nhill2090
did you remove your turbo? and if you did, did you replace the pedestal o-rings and such?
Old Mar 20, 2008 | 11:13 AM
jwhitetail's Avatar
jwhitetail
No on the turbo, just removed compressor half.
Old Mar 20, 2008 | 12:30 PM
jwhitetail's Avatar
jwhitetail
Leak looks to be on passenger side, oil is on passenger side up pipe and exhaust pipe. That line running around the back of the head is it a oil line, on passenger side.
Old Mar 20, 2008 | 06:31 PM
jwhitetail's Avatar
jwhitetail
Thank's for all the help fellows, I fixed it.
Old Mar 20, 2008 | 06:44 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
And, what was it?
