Shocks?
Old Mar 20, 2008 | 09:45 AM
FARM69's Avatar
FARM69
Shocks?
I ordered a add-a-leaf kit for my front end the other day. Would it be wise to replace the shocks as well? How/what is the procedure for our shock replacement? What shocks should I go with?
Old Mar 20, 2008 | 11:34 AM
caseydudem's Avatar
caseydudem
If you shocks still feel good then I would say no. The leaf shouldn't lift you that much.
Old Mar 20, 2008 | 01:35 PM
FARM69's Avatar
FARM69
They will level it out. I didn't get them for a lift. I'm tired of only have a 1/2 inch between the leaf and the rubber stopper.
Old Mar 20, 2008 | 01:37 PM
IceboxFX's Avatar
IceboxFX
you'll be ok. i got the add-a-leaf on my 250 and i didnt have any problem with the shocks.
unless they are shot, to test them take them out (two bolts, probably 18mm, one on top and one on the bottom) and see if once you compress them if they pop right back out. you should be able to push them in with your body weight.
if you do wanna replace them, bilstein are a really good, but expensive brand. any of the rancho/skyjacker, ect. i would put in my truck if you dont wanna spend an arm and a leg.
Old Mar 20, 2008 | 01:38 PM
IceboxFX's Avatar
IceboxFX
also if your gonna do the shocks you may need a pry bar and some spray lube.
Old Mar 20, 2008 | 01:44 PM
FARM69's Avatar
FARM69
Thanks Ice. Thats the info I was looking for. I figured since I was working with the front suspension I should take a look at the shocks.
Old Mar 20, 2008 | 02:02 PM
IceboxFX's Avatar
IceboxFX
no problem. they are a piece of cake to pull off, so you might as well check them while you got your tires and stuff off
-brian
Old Mar 20, 2008 | 07:42 PM
c00nhunterjoe's Avatar
c00nhunterjoe
the skyjacker nitro 8000's are awesome shocks and very affordable. huge difference in ride over stockers. i run the hydro 7000's, a step down but still very nice
Old Mar 20, 2008 | 07:49 PM
JethroF250's Avatar
JethroF250
i agree with joe. the best thing about me is i can get the 8000's for 30 bucks a piece cause my freind can get discounts through skyjacker
Old Mar 20, 2008 | 08:02 PM
c00nhunterjoe
even without discounts they are pretty cheap, summit racing and jegs stock them.
Old Mar 27, 2008 | 12:20 PM
ToughBuiltFord's Avatar
ToughBuiltFord
FTE Sponsor
check out skyjacker 8000s here:
http://www.autoanything.com/suspension-systems/61A2624A0A0.aspx
plus, theres a $35 mail in rebate if you order 4 by 3/31/2008
Old Mar 27, 2008 | 12:36 PM
Bird Hunter's Avatar
Bird Hunter
I have a Tuff Country leveling kit in the front of my F-250 and it provides about 1 1/2" of lift (levels the truck out). I ran the stock shocks with this for a couple of years and just recently changed to Bilstein HD's, and I like the ride. They were about $260 for a set of four at shockwarehouse.com. The front shocks have two different size bolts on them, I believe it was 18mm and 21mm, and were kind of a bear to remove and replace; the rears went easy. Icebox FX was right about the spray lube. A little spray silicone on the bushings makes the job alot easier. Hope this helps!
