Change over
Old Mar 20, 2008 | 08:36 AM
oldranger6869's Avatar
oldranger6869
Change over
Will the distributor out of a 302 work in a 351w?
Old Mar 20, 2008 | 09:09 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
oldranger6869
Welcome to (FTE)!
No!
The 351w should be longer the gear on it is bigger the oil pump drive is bigger.
You may want to take a look in our small block engine forum.
Wally Womack
Old Mar 20, 2008 | 10:48 AM
oldranger6869
Is there any way to tell what year 351w I have?
Old Mar 20, 2008 | 06:31 PM
Pro-Street/StateTK
oldranger6869
On the block just above the starter you will find the casting numbers, write
them down and someone here will help you!
P.S. Heres a link that may help!
https://www.ford-trucks.com/forums/720852-289-a.html
Wally Womack
Old Apr 22, 2008 | 01:55 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
No, they require 2 different distributors.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
Ford Distributors
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com: /><o></o>
<o></o>
<o></o>
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
<o></o>
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
