General Diesel Discussion
CASE loader Diesel
Old Mar 19, 2008 | 07:14 PM
Rackpatrol's Avatar
Rackpatrol
CASE loader Diesel
I have a case 1845 loader mid 1980's model, and I have a problem that is totally blowing me away. It runs great until it gets warmed up.(NOT HOT ) just warm according to the temp. gauge. then it loses allmost all of its power. When I Idle it down for a little while it runs great for a few minutes. and then back to the lost power again. When I get out of it and go around to the back side I notice anti freeze on top of the raditor by the cap.I am not sure if one has to do with the other but I am totally lost on this one. PLEASE PLEASE PLEASE HELPme. It is driving me crazy. also it seems to blow a little bit more light gray smoke when it acts up. Thank you for even reading this. FTE RULES It is the best sight I have ever been on.
Old Mar 19, 2008 | 08:00 PM
99whiteford's Avatar
99whiteford
Sounds like the injector pump ,or the lift pump is going bad.
Old Mar 20, 2008 | 04:49 PM
Rackpatrol's Avatar
Rackpatrol
i'll give it a look, thanks
Old Mar 20, 2008 | 05:43 PM
Rackpatrol's Avatar
Rackpatrol
Can You Tell Me Where I Might Be Able To Find A Rebuild Kit For The Injector Pump. I Have Been Looking And I Keep Coming Up Empty.
Old Mar 20, 2008 | 06:11 PM
99whiteford
I always take things like that to acme diesel in knoxville tenn.If you dont get an injector set right it can cause many high dollar problems.
Old Mar 20, 2008 | 08:06 PM
mudmaker's Avatar
mudmaker
I would just take the skidsteer to a cummins shop and have them rebuild it, probably cheaper than a Case dealer. JMO
Old Mar 21, 2008 | 06:19 PM
gbadgley's Avatar
gbadgley
Does that model have an inline filter buried down near thebottom of the fuel tank like the 40xt? Also make sure you use a mesh filter in line and not a paper filter. Greg
Old Mar 24, 2008 | 08:37 PM
Rackpatrol's Avatar
Rackpatrol
no but it does have a double filter system. one right above the other right befor the fuel injector pump.
Old Mar 25, 2008 | 08:14 AM
Kwikkordead's Avatar
Kwikkordead
I was going to say clogged fuel filter as well.
Old Mar 25, 2008 | 08:59 PM
Rackpatrol's Avatar
Rackpatrol
I have changed both filters, and there was no differance I guess I could try blowing out the fuel lines and the primer pump. It's worth a shot.
