steering wheel shudder
Old Mar 19, 2008 | 06:09 PM
fx4soon's Avatar
fx4soon
hi guys,i have a new 08 f150 fx4.i had the tires changed before taking the truck,also had a 2.5 level kit installed before taking the truck from dealer.the tires i put on are bfg's km2's mud terrain.i had a wheel alignment done right away.now that the roads are starting to clear of ice i can feel a wooble in the sterring at highway speeds.so i had my tires balanced again to make sure that this is not the problem,well any way aftre trying the truck on the highway again the wheel still woobles. anyone have any ideas.thanks for your help.i should mention that the truck only has 1000kilometers on it. lionel
Old Mar 19, 2008 | 06:49 PM
F0rdzTuff's Avatar
F0rdzTuff
Hit anything while mudding? Bent rim? Driveshaft? Tie rod ends? Dunno' my friend from the North...(I'll assume that since you quoted your mileage in KM's.)
Old Mar 19, 2008 | 07:04 PM
fx4soon's Avatar
fx4soon
yes your right i am in labrador canada.this truck has not seen any type of off roading yet.truck is all black,not sure it will ever see off road.i forgot to say my tires are 35/12.5's
Old Mar 20, 2008 | 05:48 PM
fx4soon's Avatar
fx4soon
ok guys, i have some new info and still more questions.today i had my tire shop look at the tire balance again,they decided to use a system which uses silicone beads inside the tire to balance,he tells me the tire is perfectly balanced.tried the truck on the highway and as soon as i hit 60kph the steering goes nuts,but the truck tracked straight.slowed down and tried her again and nothing the steering wheel is dead still.tried again and the steering wheel is shaking like crazy!!!!tried this many times and the result always seemed to alternate.so do you guys think this could be the tires,i mean the tire shop said they are balanced,so the would not be differant on the machine than on the truck,would they?anyone have any ideas i can check? thank you for your time.
Old Mar 20, 2008 | 06:31 PM
F0rdzTuff's Avatar
F0rdzTuff
Check your tie-rod ends...When they did the alignment, they screwed something up is what it sounds like to me. Your tires are spreading apart...your toe is off.
Old Mar 20, 2008 | 06:46 PM
fx4soon's Avatar
fx4soon
that sounds like a very good suggestion.what ever the problem is it is getting worse every day.thanks for your help.
Old Mar 20, 2008 | 08:41 PM
Tom's Avatar
Tom
Not to sound cocky here, but...
You took a brand new truck, altered the suspension configuration, put huge tires on it...
and expect it to drive perfectly?
HartleyJW
Nov 29, 2010 08:13 AM
john smith jr
34
Aug 16, 2010 01:00 AM
Michigan Rick
19
Oct 13, 2008 05:16 PM
foru2nv4
1997 - 2003 F150
Jan 10, 2005 09:46 AM
