Cowl
Old Mar 19, 2008 | 04:37 PM
Joker50's Avatar
Joker50
Question Cowl
Is there a gasket or rubber seal that fits under the cowl vent? My F-1 has a cowl vent but I noticed that it leaks a little water through the vent even if it is closed. Any help and ID of a part would be greatly appreciated!
Joker50
Old Mar 19, 2008 | 05:12 PM
Walston's Avatar
Walston
What year?
Old Mar 19, 2008 | 05:26 PM
bobj49f2's Avatar
bobj49f2
Yes, there is a gasket that screws to the cowl.
Dennis Carpenter part# 7C-8102330-A for $8. I also would assume some of FTE sponsors would have them too.
Old Mar 19, 2008 | 06:01 PM
gumbybm's Avatar
gumbybm
does it screw to the cowl or is it glued to the cab body? The book says to glue it to the cab?
Old Mar 19, 2008 | 06:23 PM
Joker50's Avatar
Joker50
Smile Cowl 2
I have a late 1950 F-1. The engine runs fine. It just needs a little body work and good paint job. I appreciate all of your help and be sure I will be driving without a wet floorboard.
Joker50
Old Mar 19, 2008 | 07:27 PM
bobj49f2's Avatar
bobj49f2
The rubber seal, part #02230, placed around the lip on vent, part #02104, is screwed into the cowl by a 6 or 8 screws, part #35999-S. You will see holes in the rubber for the screws.
Old Mar 19, 2008 | 07:40 PM
gumbybm's Avatar
gumbybm
Is it different from 53 instalation?
Old Mar 19, 2008 | 08:20 PM
bobj49f2's Avatar
bobj49f2
It might be different for a '53 but I don't have any experience with anything newer than '52.
Old Mar 19, 2008 | 09:21 PM
eman92082's Avatar
eman92082
As it should be.......
