Speed Control recall - ?
Old Mar 19, 2008 | 02:52 PM
CMOS's Avatar
CMOS
Do any of you know SPECIFICALLY how the recall is implemented?
I know Ford uses a small harness with a male and female connector that splices in series with the brake control swithc on the mater cylinder.
What I want to know is - what does that harness include/do?
CMOS
PS: I ask this because the dealer just disconnected my cruise when I took it in for some other service. They don't have the recall part and have no idea when they will have it, and I'd sure like to have my CC back for a long trip in a few weeks. If I know what/how this fix does, I may be able to reeproduce it myself.
Old Mar 19, 2008 | 08:25 PM
rscalzo's Avatar
rscalzo
Recall
Find a different dealer. Mine had the parts the day I received the recall letter. Took all of thirty seconds to complete.
Old Mar 19, 2008 | 09:39 PM
CMOS's Avatar
CMOS
Well, it's ood - after they told me they didn't have the parts, on a hunch, I called the parts deprtament. "We have plenty of these in stock."
Service writer, who I have uesed for the last 12 or so years looks into it and says FOMOCO says not to use the parts in stock, that a newer part is coming out for the recall.
My question still is - what does the recall part do? An in-line fuse? A series resistor? What are they doing to remedy the recall?
CMOS
Old Mar 20, 2008 | 07:38 AM
MCDT's Avatar
MCDT
What... so there is a recall on the recall?? So my 01 EB that had the recall done last fall has got the bad new parts?
Old Mar 20, 2008 | 07:51 AM
CMOS's Avatar
CMOS
I don't know. I only know what I was told.
If I can get a better understanding of WHAT the recall does I'll do the damn thing myself just so I don't have to wait and take it back in again for 10 minutes fo work.
MCDT - do you have the receipt from the dealer when they did the recall for yours? Got a part number?
CMOS
Old Mar 20, 2008 | 01:22 PM
MCDT's Avatar
MCDT
Man you are asking a very disorganized person to find something from months ago! Let me see what I can do when I get home from work.
Old Mar 20, 2008 | 01:36 PM
scucci's Avatar
scucci
Ford says that some of the harnesses that were shipped for the recall were incorrectly made with the fuse in the wrong wire. I have heard that a newer part with fuses in both wires is coming out. Ford wants the dealers to disconnect the cruise switch until the new part is in stock. That what I've been told.
Scucci
Old Mar 20, 2008 | 03:29 PM
CMOS's Avatar
CMOS
Some more info I found out from my service advisor (after all but holding a gun to his head...): He says the issue stems from the brake switch sensor (on the master cylinder resevoir assembly) leaking brake fluid through the sensor. Fluid messes with the connector shell and electrical contacts causing a high resistance connection = heat = burnt connector and or wires = sometimes marshmallow roating flames. He figures "maybe sometime in May" for the part to be available.
My sensor is bone dry and has no discoloration on it or the connector, so I hooked it back up. Going on a trip in a couple weeks, honeymoon actually and I do want the CC for that trip.
CMOS
Old Mar 20, 2008 | 06:39 PM
Rick55's Avatar
Rick55
CMOS,
Congratulations!! May you never have a fight!
Rick
Old Mar 20, 2008 | 07:08 PM
ukexplorer's Avatar
ukexplorer
Unhappy
The area around the connector to the cruise control swith on the master cylinder was insulated with a special material called Kapton (Google "Kapton", it will scare you to death). The problem with this material is that it has been known to spontaneously combust whether it is carying current or not causing fires under the hood. The replacement part is made with a more conventional insulation. Unfortunately, this insulation was developed for aerospace use and is used extensively on the airplanes we all travel in!
CMOS
May 23, 2012 09:07 PM
AreWeThereYet
Dec 22, 2011 12:09 PM
srgntrbt
2004 - 2008 F150
Mar 20, 2011 09:45 AM
jake00
Feb 3, 2008 09:53 PM
CMOS
1983 - 2012 Ranger & B-Series
21
Feb 26, 2007 07:35 AM
