Fuel filler lines
Old Mar 19, 2008 | 08:36 PM
gabocar's Avatar
gabocar
Red face Fuel filler lines
Hi:
This is a newie question.
Which is the correct method to remove the two fuel filler lines attached to the fuel tank?
I tried more than one hour to remove it, and i couldn't loose it. The problem were the little white clamps, i couldn;t remove it.
Please any trick will be appreciated.
1996 4 dr Explorer
Gabo
Old Mar 19, 2008 | 10:23 PM
gabocar's Avatar
gabocar
Anybody? I'm in the middle of the job.
Thanks
Old Mar 20, 2008 | 01:11 PM
5.0B2's Avatar
5.0B2
Did you get the retainer clips out? If you can, spread the ends a little, then pull them out. I usually expect to break them in the process and buy new ones at the parts house. the lines will pull straight off after you remove the retainers.
Old Mar 20, 2008 | 01:41 PM
gabocar's Avatar
gabocar
This is my problem, i cant out the clips. I saw two parts of the clips around the tank and inside the tubes. But i cant find the way to remove it.
Thanks
Old Mar 20, 2008 | 03:05 PM
marragtop's Avatar
marragtop
Do a search on 'fuel filter'. There are some very good detailed posts on how to disconnect the lines.
Old Mar 20, 2008 | 10:06 PM
eallanboggs's Avatar
eallanboggs
Are you talking about the fuel tank OR fuel filter. You seem to be mixing up the two. If you mean fuel filter those little plastic clips usually come in the box with the new filter. If your filter uses the metal type clips you need a Special Tool to compress the three tabs on each end of the filter/fuel line junction. You have to slide the tool over the fuel line and push it all the way to the filter. The tabs will release and the fuel line will pull out of the filter. It's sometimes hard to get the fuel line out of the filter. You'll need to push the tool in as far as you can and while holding the tool in as tight as you can you have to pull the fuel line and fuel filter in opposite direction. You will need three hands to do this part.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Aug 8, 2014 10:54 AM
glovemeister
Jul 2, 2013 06:06 PM
JimJr15
General Diesel Discussion
Mar 31, 2011 01:24 PM
JSP2242
Nov 9, 2010 06:40 PM
