Oil and filter change interval
Old Mar 19, 2008 | 01:57 PM
sum_weirdo's Avatar
sum_weirdo
I gave my 78 F250 an oil change shortly after I got it last year. Since then it's spent most of it's time sitting idle since it's not a daily driver truck and it doesn't do well in the winter anyway. Now that spring has sprung it's time for it to shake off the dust and be active again and I'm wondering if I should change the oil again. As far as distance travelled it's probably only been a few hundred kilometers since the last change but it's been about 7 months or so. I use Rotella 15W-40, think it will have deteriorated or anything in that time? Just wondering if I should be changing the oil every 3 months whether the truck has moved alot or not.
Old Mar 19, 2008 | 02:02 PM
Don S.'s Avatar
Don S.
I personally would change it, seeing that condensation can build up just sitting, and seeing I don't have an oil temp gage, you never really know if the oil runs above 212 Deg. F to ever really boil it off.
Old Mar 19, 2008 | 02:07 PM
fdude64's Avatar
fdude64
typical intervals for oil change is 3000 mi or three months which ever comes first
Old Mar 19, 2008 | 02:14 PM
sum_weirdo's Avatar
sum_weirdo
That's what I thought, just wondered if it was a myth created by Mr. Lube or something. Thanks.
Old Mar 19, 2008 | 02:33 PM
duste's Avatar
duste
I don't change the oil before storage in the winter but I do change it as soon as I take it back out. Sitting all winter or limites use causes alot of condensation in the oil system. I also don't start my engine at all during winter but I do roll it over with the coil unhooked till I get oil pressure at least monthly, this keeps condensation from forming in the engine and exhaust system. As far as intervals go every 3000miles is a good standard to go by.
Old Mar 19, 2008 | 02:37 PM
Mil1ion's Avatar
Mil1ion
In a crunch ?
It is always more important to change the filter,...than the oil.
Old Mar 19, 2008 | 05:23 PM
73f100shortbed's Avatar
73f100shortbed
3 months or 3000 miles is good to go by. I change mine probably more than that just because....
Old Mar 19, 2008 | 05:29 PM
Diesel Man 03's Avatar
Diesel Man 03
My truck sits most of the winter and I change it like in dec and then in probably april.I put maybe 4000 miles on it during the summer and I have no condensation problems.I personally don't believe the 3000 miles or 3 months change.
Old Mar 19, 2008 | 05:44 PM
m78's Avatar
m78
Where is it stored ? If it's not subjected to, to much temp change it shouldn't have a condensation problem
Just a thought
Old Mar 19, 2008 | 10:18 PM
sum_weirdo's Avatar
sum_weirdo
It's stored outside. Won't fit in my garage
Old Mar 20, 2008 | 12:51 AM
Mecinoid's Avatar
Mecinoid
I go by the rule 3000 miles for reg oil or 5000 for syn. Either way I change the oil every six months to get acids out of the case that build up. Plus, oil tends to breakdown because of those acids and contaminates. Even if you only put on 1000 miles in that period of time. Oil changes are cheaper than a tank of gas now so it's a safe and good practice to get into.
I don't believe in every three months. Then again I have many cars so I'd always be under one just changing oil everyday if that was the case. No really, I have a spreadsheet with date and mileage of last oil change and other important maintenance info so I don't forget to do one of my task and screw up something. ;-)
I always check oil level with at least every other gas fill.
