Sponsored by: Auxito
rough idle when its damp
Old Mar 18, 2008 | 08:03 PM
smartj's Avatar
smartj
Hi all
I have on 03 f150 4x4 with the little v-8 and auto and 50k miles. The truck runs fine most of the time. Except when the weather is cold and wet and truck is still cold I'll start it up and it will idle real rough and hesitate when its driven. It seams once the motor is warm if I restart it runs fine. The check engine light hasn't come on. also it doesn't do this every time its cold and wet, maybe 4 time in the last year or so. Any Ideas whats going on .
There a k&N Air filter in it if that makes any differnce.
Thanks jesse
Old Mar 19, 2008 | 12:46 PM
Thudpucker's Avatar
Thudpucker
My 97 does that too. Some guys say the IAC needs cleaning. I'm just soooo unmotivated about getting into my engine I havent tried that to see if it works yet.
Old Mar 19, 2008 | 08:59 PM
LxMan1's Avatar
LxMan1
Welcome to the forum
Sounds like it's time to pull the coils and inspect the boots. If they look ok, add some dielectric grease to them and reinstall. Sounds like moisture is causing a misfire.
Old Mar 20, 2008 | 07:03 AM
smartj's Avatar
smartj
I'll Give that a a shot. I used to have a bronco II and got real good at cleaning the IAC, so I'll check that out at same time. When inspecting the boots am I looking for anything in particular or just deterioration.
Milly1219
2004 - 2008 F150
Jun 11, 2014 09:48 PM
superduty4x4
13
Nov 29, 2011 11:12 AM
crp2000eb5.4
28
Jan 18, 2008 07:48 AM
viperbluelx
Jul 23, 2007 09:51 PM
wgm114
Dec 16, 2000 12:45 AM
