Is this right??
Old Mar 18, 2008 | 07:59 PM
97-psd's Avatar
97-psd
Is this right??
My ABS light came on this morning and my speedo stopped working too, and from what I have found in my searches is that the differential sensor may be un-hooked. Right, wrong, other reasons for the problem??
and I know this sounds retarded but is the differential sensor actually on the rear differential or some where else??
Old Mar 18, 2008 | 08:51 PM
DPorter's Avatar
DPorter
front side driver side up top
Old Mar 18, 2008 | 09:16 PM
Towmanjbo's Avatar
Towmanjbo
I had this problem recently with my F150 and this is what I did (I'm guessing the vss is the same on these axles). https://www.ford-trucks.com/forums/7...vss-broke.html
Old Mar 18, 2008 | 09:40 PM
tjbeggs's Avatar
tjbeggs
Right on! had mine break this winter when too much snow (there was 15 inch fresh on the road!) built up and snapped the sensor in half!
Old Mar 18, 2008 | 10:43 PM
onefarmer's Avatar
onefarmer
Check the fuses first. I had the same issue with my '95 F150 and it was a fuse down by your left knee.
Old Mar 19, 2008 | 10:16 AM
MagKarl's Avatar
MagKarl
I think you're right. Same thing happened to me a month or so ago, ABS light came on and no speedo. Replaced Rear Antilock Brake Sensor -RABS, for about $20. Piece of cake, it's right on the top of the rear diff held in by one bolt, maybe 12 or 13mm, can't remember exactly.
Old Mar 19, 2008 | 06:13 PM
97-psd's Avatar
97-psd
thanks for the help guys, I got under this afternoon after work and one of the wires had broken, put it back together and everything is back to normal thanks again for the help
