Tranny Maint
Old Mar 19, 2008 | 12:06 PM
uliman's Avatar
uliman
Mark, thank you for the correction. I take it from your post that, if you can find Mercon/Dexron III (by the way, both Sams Club and Costco sell this stuff by the cases - about $22 for a case of 12 qts) it can still be used in the 4R100. Using your method, I changed the fluid in my F250 last year and had absolutely no problems with the Mercon/Dexron III. I would probably change to Mercon V but since my current F350's transmission will likely fail soon, I will just wait until I can afford a JW or BTS transmission as I intend on keeping my truck for quite a long time.
Old Mar 19, 2008 | 01:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You can still use MERCON/DEXRON III.
