Swapping beds...
Old Mar 17, 2008 | 10:22 AM
16Vjohn's Avatar
16Vjohn
Swapping beds...
Will the bed from a 93 F250 bolt to the frame of an 86 F260? The beds are almost identical in length.
Thanks Forum.
Old Mar 17, 2008 | 11:13 AM
80demoace's Avatar
80demoace
Yes, the wheel opening will look a little different but it will bolt directly on.
Old Mar 17, 2008 | 11:23 AM
16Vjohn's Avatar
16Vjohn
Excellent! I'll remove the 86's bed tonight and that will give me a chance to redo all the wiring for the lights... Anyways... thanks!
Old Mar 17, 2008 | 02:29 PM
Sycostang67's Avatar
Sycostang67
The newer bed will only need 6 bolts instead of the 8 bolts used by your old bed. I have a 93' bed on my truck.
Old Mar 18, 2008 | 10:55 AM
5_labsownus's Avatar
5_labsownus
As said before it will fit and the 6 bolts will line up with the holes in the frame for the old bed.
Old Mar 18, 2008 | 12:04 PM
ri_truck_guy's Avatar
ri_truck_guy
You could have either an 8 or 6 bolt bed on your 86. They began the change to the 6 bolt fastening system that year. If you have an 8 bolt bed on your 86, get the bolts with the 93 bed. They will be different from the 8 bolt bed where they attach to the bed.
