351c 2v Head Porting?
Old Mar 17, 2008 | 10:04 AM
EFM's Avatar
EFM
Question 351c 2v Head Porting?
72 351C 2V .030 over, speed pro pistons 9.1 comp
ferrea valves, double v springs, roller rockers, air gap intake
needs: cam, headers, ignition system
I'D LIKE TO DO SOME PORT WORK OR CLEAN-UP ON
MY HEADS. I'VE NEVER DONE IT BEFORE BUT AM LOOKING
FOR ADVISE. IF I CAN DO IT I WILL, IT IS NOT A MUST
SO I DON'T WANT TO DISH OUT MONEY TO A PRO BECAUSE
I'M NOT BUILDING A RACE TRUCK.
ALL CONSTRUCTIVE CRITISISM AND OPINIONS APPRECIATED.
Old Mar 17, 2008 | 01:36 PM
mustang81's Avatar
mustang81
You can do a little porting on the exhaust side.
Old Mar 17, 2008 | 11:04 PM
EFM's Avatar
EFM
What About Smoothening The Intake Or Do
I Just Leave It Alone
Old Mar 18, 2008 | 09:11 AM
hollenjoe's Avatar
hollenjoe
the intake side is good as is, just machine your intake valve seat to fit a 2.19" one, it willl better your flow...
Old Mar 18, 2008 | 01:34 PM
EFM's Avatar
EFM
U Know, Just Yesterday I Recieved My Ferrea Valves
2.07 And 1.65 And I Would Hate To Do A Return. How
Much Differance Is There In Power.
Old Mar 18, 2008 | 02:46 PM
hollenjoe's Avatar
hollenjoe
jajaj its not a must do, but it will help....
Old Mar 18, 2008 | 08:21 PM
danlee's Avatar
danlee
Look here:
http://www.sa-motorsports.com/litera...05.06B_MED.pdf
Don't do any work on the intake port, but you can do shortside radius and bowl work on both the intake and exhaust ports. The exhaust port should be polished as smooth as possible.
Old Mar 19, 2008 | 07:31 AM
EFM's Avatar
EFM
Thanks For The Link Danlee
Should I Port Match The Intake Side?
Old Mar 19, 2008 | 07:41 AM
danlee's Avatar
danlee
No, the Intake Manifold outlet port should be smaller than the head inlet port to reduce reversion.
Old Mar 19, 2008 | 07:46 AM
EFM's Avatar
EFM
What's Reversion?
Old Mar 19, 2008 | 08:20 AM
danlee's Avatar
danlee
What's Reversion?
Reversion is a pulse of air/fuel mixture that is reflected off the intake valve after the valve closes. It is the result of the wave motion that's setup in the intake manifold and head when the mixture reaches high velocity. This wave motion is beneficial, since it increases the charge in the cylinder, but the reflections into the intake manifold can cause turbulance and reduce the flow. Intake manifold manufacturers design their manifolds to reduce this reversion. Any attempt to port match will compromise this feature.
Old Mar 19, 2008 | 08:36 AM
EFM's Avatar
EFM
Oooohhh!
So I Won't Touch The Intake Manifold
But Should I Match The Gasket To The Head?
Thanks Again!
Old Mar 19, 2008 | 09:37 AM
danlee's Avatar
danlee
Oooohhh!
Thanks Again!
The gasket should be close to the port size and location. A small amount of matching will be OK, but if there is a lot of material that needs to be removed, it's time to find different gaskets.
Old Mar 19, 2008 | 11:30 AM
mustang81's Avatar
mustang81
Oh no! I port to match gasket to manifold and head and sand manifold with fine grid to smooth everything, almost polish!
Danlee what is the short side radius and bowl work?
arround the valve (inside the head)?
Old Mar 19, 2008 | 12:01 PM
fordeverpower's Avatar
fordeverpower
Imho, the short side on those heads are the worst of seen, nearly a 90 degree angle. They can be rounded and smoothed easily, just did a set for a dirt track car. The bowls can be opened up some as well. i wouldn't mess with any guide work if your seats are done already. A good multiangle valvejob and good valves help a lot.
