Speedomoter 2
Old Mar 16, 2008 | 06:40 PM
Joker50's Avatar
Joker50
Angry Speedomoter 2
I asked a speedometer question earlier and got great advice but I can't seem to make things happen. I am trying to connect the speedometer cable to the back of the speedometer on my 1950 F-1 but the stem doesn't want to insert enough to screw the cable on. Of couse I cannot see what I am doing. I even got my son (who is much smaller than me) who can lay on the floorboard and see the back of the speedometer but he had the same problem. Should I continue to be persistent or am I doing something wrong? It seems so simple but it is causing headaches.
Joker50
Old Mar 16, 2008 | 07:07 PM
mechmagcn's Avatar
mechmagcn
You have one of three problems, either the core is too long, the core isn't inserted into the gear at the transmission, or you are not getting the core into the drive on the rear of the speedo. Check the core to see how far it is sticking out of the housing, it should be about 1/2" past the end, if it is farther out, try turning the core and pushing it farther in.
Old Mar 16, 2008 | 07:21 PM
Joker50's Avatar
Joker50
Thanks for the advice mechmagcn. I will try find out which one of the three problems it happens to be.
Joker50
Old Mar 16, 2008 | 08:33 PM
ALBUQ F-1's Avatar
ALBUQ F-1
....or part of an old cable is broken off inside the spindle in the speedo. It's not much trouble to take the speedo out, might be worth it to check and also to lube it.
Old Mar 16, 2008 | 09:01 PM
Joker50's Avatar
Joker50
This sounds like my next task. It is a 1950 F-1 and I am sure it hasn't been lubed in years or decades. Thanks for the info!
Joker50
