327 stroker
I was just reading up on this actually, I'm an information junky, I like to be well informed before making decissions. I was skeptical of even building the 331 as so many high reving stangs and such use it. Further reading revealed that these strokers are capable of some real nice low end numbers. I have been looking at a cam setup from Crane as a preliminary thing it's range is Idle - 4800 and they have the full roller rockers as accessories for it etc.
I was only wondering that if a cam is designed for a 302 will it give the same benifits to a 331? or will the increased stroke effect the cam timing?
the Cam part # is 363904
That's the $64,000 question. You are effectively changing the dynamics of the motor, and it is my belief that you need to step up one more grade in the cam department. You have more displacement and usually more CR, which make a larger cam act smaller. As far as the low end thing goes, the people who SPIN these motors for power are looking for the extra cubes stroking delivers, but to take it on a strictly mathematical level, increasing stroke increases torque, and high revving motors need LESS stroke and more bore and sometimes motors are DESTROKED to make high RPM screamers. I would go with the 1,500- 5,500 ( or whatever the high range is) cam. You may get different opinions on this, a lot of it has to do with what CR you will be running.
I know it's for ricer's but the basic info will be the same. http://www.importtuner.com/tech/0802...eparation.html
i have a 331 stroker in my 95 f150 5speed
i tried the efi idea and i had to use a whole gt40 lower an upper intake and i had to get a computer made to handle fuel issues i also used a 302 boss block from ford racing, and keith black pistons and stuff from summit racing. and fastlane mustang i produced 430rwhp on my first dyno run and 450 on my second run. but it all depends on what u want ur motor to do
Fellenz
12-11-2014 10:58 PM
1990f150kid
03-22-2012 08:57 PM
chevyassasin
10-10-2011 04:23 PM
C-Leigh Racing
03-10-2009 10:40 PM
Tdvjensen
29
04-10-2007 12:25 PM
