351C oiling system
Old Feb 14, 2001 | 12:28 AM
ole_blue's Avatar
ole_blue
351C oiling system
OK fellas have just purchased a 1980 f150 4x4 with no motor in the truck but with that purchase I also recieved a 351C and c6 tranny with only 40K miles on the mated pair for $1000 dollars the truck also has5 inches of total lift. I have already purchased a milodon 8 qt pan and pickup for $75 and a HV oil pump.
my question is what else can or should I do to make sure the heads get plenty of oil in the right spots?????
Old Feb 14, 2001 | 12:32 AM
ole_blue's Avatar
ole_blue
351C oiling system
oh yeah my other question is what is the estimated horsepower and torque of this 1974 351C 2v out of a 1974 ranchero
IF YA AIN'T BEEN STUCK........ YOU AIN'T BEEN 4 WHEELING
Old Feb 14, 2001 | 02:23 PM
Franklin2's Avatar
Franklin2
351C oiling system
They didn't make a 351c in 74 did they? Is it a M?
Old Feb 14, 2001 | 04:02 PM
bubbaf250's Avatar
bubbaf250
351C oiling system
ole_blue,
Don't worry about getting oil to the heads. If you rev it hard, you'll have to worry about getting too much oil to the heads.
>351C 2v out of a
>1974 ranchero
Actually, 1974 was the last year they made the 351C.
Factory rating in 1974 for the 351C 2V was 163hp.
Sorry, I don't have torque numbers.
BubbaF250
1980 F250 4x4 Custom, 351M/NP435/NP208/D44HD-TTB/D60-FF/3.55s 6750 GVW, Rust & White.
Old Feb 14, 2001 | 04:26 PM
Bill_Beyer's Avatar
Bill_Beyer
351C oiling system
The only modification you might need to make for a street engine is to put an external oil line from the oil passage in front of the fuel pump to the O.P. sending unit passage. Put in a T fitting so you can retain the O.P. sending unit. This is the same modification as you'd make on an M block. There's a page with a well documented Cleveland build up at:
http://www.geocities.com/MotorCity/Flats/3845/cleveland.html
Old Feb 14, 2001 | 06:54 PM
ole_blue's Avatar
ole_blue
351C oiling system
>74 did they? Is
>it a M?
yep Frank they did. 71-74 were the production years
Old Feb 16, 2001 | 07:35 PM
ole_blue's Avatar
ole_blue
351C oiling system
Hey Bill thanks for the info. i did the oil line mod and i'm installing the motor this weekend.
IF YA AIN'T BEEN STUCK, YOU AIN'T BEEN 4 WHEELING
Old Feb 18, 2001 | 05:47 PM
mtflat's Avatar
mtflat
351C oiling system
danlee
19
Jan 13, 2009 08:25 PM
imlowr2
Engine Swaps
Dec 11, 2007 11:31 PM
joelgator
Dec 28, 2004 12:52 PM
pcmenten
Dec 15, 2002 08:24 PM
78Bronco1
Oct 9, 2002 06:15 PM
