the bellhousing pictured above is for a ford y-block series v-8 that was used in trucks thats been modified to accept a 5.0 mustang t-5 5spd manual transmission. the car bells dont have the ears on the side.
from my understanding, the three speed and 4spd bellhousing is different. the one in the picture is for a 4spd i do believe. The 4spd that bolts up to the one in the picture is a t-98A. hope this helps.
THAT, Mr Walston, is the same as my 4 spd bell (with a lot less grime!). I would have to say the Mummert bell pictured is for the 3 speed. It has been modified, with the 2 bungs welded on, but the original bolt pattern is still intact.
Seems then, the top 2 bolt holes for the 4 spd and the bottom 2 holes for the 3 spd align to the t-5. Interesting.
