Edge with Gauge pod...
Old Mar 16, 2008 | 10:22 AM
BandBFord's Avatar
BandBFord
Well... My Edge (along with my Volant) are on the way from Jusnes so I'm anticipating the arrival however, I do have one question...
Does anyone currently have an Edge installed with a dual gauge pod mounted on the "A" pillar or does anyone know if the two will clear each other? I need a gauge mount for a Whistler Fuzion and a vac/boost gauge preferring the pillar mounted one instead of ones in the center of the dash.
Thanks in advance...
Old Mar 17, 2008 | 07:38 PM
Twinsdad98's Avatar
Twinsdad98
I don't have a gauge pod, but I do have the edge installed. It's about 3" tall, so depending on where the gauges are, it will be a tight fit. I don't think it'll work because of the grab handle and the contour of the A-pillar...
Old Mar 17, 2008 | 08:02 PM
black04lariat's Avatar
black04lariat
If you have the flow thru console, I have my Edge mounted where the ashtray is. I liked it there over the pod mount.
Old Jun 13, 2008 | 12:22 AM
mattd17's Avatar
mattd17
bump....... i am looking for the same type of setup to mount my airbag pressure gauge. but, im having trouble finding just what i want.... anyone with ideas? tia !!
