Tube from front differential?
Old Mar 16, 2008 | 02:13 AM
xfactor_279's Avatar
xfactor_279
Hey guys I dont know if there is a thread about this already but I noticed this while changing my oil the other day.
There is a tube about 2 feet long coming out of the top of my front differential on my 86 F150. The tube was just hanging over the axle dangling in the wind. I dont know if is supposed to be connected to something or not. Thanks guys.
Old Mar 16, 2008 | 02:25 AM
maverick1701's Avatar
maverick1701
sounds like the breather, I just got done adding breathers to my diffs a few weeks ago.
Keeps the nice warm axle from hitting water, expanding and sucking in that nice muddy cold water. I ran mind up high into the body, because you never know when you will have to ford a river lol
Old Mar 16, 2008 | 02:26 AM
khadma's Avatar
khadma
Carpenter Local 745
Axle breather tube, your rear should have one too!
I belive it is suppose to have a clip on the crossmember to attatch too.
The end of the tube should also face the ground.
Old Mar 16, 2008 | 02:48 AM
xfactor_279
thanks for the quick reply guys!
Old Mar 16, 2008 | 04:13 PM
Mat J's Avatar
Mat J
can you post a pic of where these are my truck done have them or atleast i dont see them
Old Mar 16, 2008 | 04:48 PM
Franklin2's Avatar
Franklin2
The one in the rear comes out of the t-block for the brake lines. You should have a nipple sticking up out of the t-block. I can't remember the front exactly. The transfer case also has a rubber hose coming out of it on the top if you have 4x4.
Old Mar 17, 2008 | 09:51 AM
xfactor_279
Sure I will try to post pics by tonight
Old Mar 17, 2008 | 10:11 AM
Mat J's Avatar
Mat J
thanks apparently mine is missing the tubes because i cant find them still.
Old Mar 17, 2008 | 10:17 AM
BChance's Avatar
BChance
I've seen them without tubes, just a cheezy little plastic vent cap direct to the housing.
Check these out:
http://purplecranium.com/c-53688-diff-cleaners.html
