Offroad & 4x4
Transfer case questions
Old Mar 16, 2008 | 12:53 PM
chrono4's Avatar
chrono4
I don't really see why you couldn't. The biggest issue would be having the jack shaft made, but any competent driveline shop could do that if you went that route, you would just have to make some kind of raised cover with a seal to keep fluid in the case. Would be as simple as a proper sized piece of pipe, with a flange on one side to bolt it to the case, and a end cap on one end with the right sized seal housing in it. make it just tall enough to stick out from the case
Old Mar 16, 2008 | 12:55 PM
STGFordCrazy04's Avatar
STGFordCrazy04
maybe youre right.
Old Mar 16, 2008 | 01:13 PM
chrono4's Avatar
chrono4
This would be the bling way to do it
But I dont think you will find one of these for your case.
The only issue I could forsee with the way I said, is the lack of support on the rear of the jackshaft, but this would only matter if there was a decent amount of slop in between the 2 splined shafts, and there shouldn't be. Plus, a big ole' gob of grease in the female side would fix that problem.
http://www.ottindustries.com/divorcetoyota.htm
Old Mar 16, 2008 | 11:26 PM
khadma's Avatar
khadma
Carpenter Local 745
Thanks for the input you guys, When Andrew mentioned divorcing the TC, I figured it might be able to do. The configuration of the BW1354 may lend itself to this concept. With this said I will consider this as an option and I feel that a good driveline shop can make an input shaft/coupling to the TC.
brian42
Apr 30, 2015 11:43 PM
winginit
Transit Connect
May 3, 2014 01:00 AM
kidoo
Mar 8, 2013 10:01 AM
Robbgt
17
Jan 12, 2009 02:19 AM
ernesteugene
22
Mar 13, 2007 02:48 AM
