Plastic Cowl Question
Old Mar 15, 2008 | 10:59 AM
JerrySC's Avatar
JerrySC
I noticed that on my '06 F-150 the driver's side black plastic cowl doesn't have all the drain holes in it like the passenger side one does. The identations are there but there are no openings in the bottom like the passenger side cowl has. After I wash it, water sits in the cowl because there is nowhere for it to go. Before I take a drill to this thing, is there a reason why it is like that?
Old Mar 15, 2008 | 11:01 AM
yellowboy's Avatar
yellowboy
I've noticed that also, must be a reason they did not perforate it.
Old Mar 15, 2008 | 02:01 PM
Ryan50hrl's Avatar
Ryan50hrl
i don't know that theres adaqute drainage down below there to clear any water coming though the holes.....
Old Mar 15, 2008 | 02:37 PM
gcozmo's Avatar
gcozmo
I was wandering about this myself. I even considered taking a 1/16" drill bit and putting the holes in there to drain them out.
Old Mar 15, 2008 | 04:27 PM
JerrySC's Avatar
JerrySC
Cowl Mystery
Well, I see I'm not the only one wondering about this. There is either a good reason for it or it's simply an oversight on the parts. Maybe someone will know and answer us soon. If not, I have a drill!
Old Mar 16, 2008 | 04:39 AM
BlueOvalFitter's Avatar
BlueOvalFitter
Question
It could be for aerodynamic purposes!
Old Mar 17, 2008 | 07:09 PM
Frd67cobra's Avatar
Frd67cobra
I wouldn't take a drill to it. Not sure, because I haven't removed it, but I believe your wiper motor is under there and the cowl on that side is solid to keep water away from the motor and related wiring.
Old Mar 17, 2008 | 07:17 PM
Ryan50hrl's Avatar
Ryan50hrl
ahhh...thats a very good point....the motor and electrical is under there....
Old Mar 17, 2008 | 07:19 PM
bradplock's Avatar
bradplock
i think frd67cobra is correct, the motor is directly underneath the non perforated part of the cowl. i recently had mine off for a windshield replacement and took notice then. thing is, it rained while the cowl was off and i washed the truck without it. wipers work fine, the motor is sealed up well. i guess it protects over the long run.
Old Mar 18, 2008 | 05:02 PM
JerrySC's Avatar
JerrySC
Thanks
Now that makes sense.
Old Mar 18, 2008 | 11:48 PM
blue 2004 FX4's Avatar
blue 2004 FX4
Yes the cowl has no drainage because there is a electric motor under that part. I have seen other people drill that out but I would not recommend it.
