Sponsored by: Auxito
Transfer Case Fluid
Old Mar 15, 2008 | 10:57 AM
bowdog's Avatar
bowdog
Wink Transfer Case Fluid
The transfer case will take the same fluid my tranny takes, MerconV, corrct?
If so, how much fluid does it take? Is there a drain plug to easily remove the old stuff? if so, where is it located?
I really appreciate the help....I am mechanically challeneged but I have learned a great deal from this awesome site about my awesome truck!!!
Old Mar 15, 2008 | 11:49 AM
Ultramagdan's Avatar
Ultramagdan
That reminds me to change mine.
The drain and fill holes are located under the shift motor on the backside of the case. Make sure you have a way to put the fluid in the fill hole. Fill it until it starts to run out and then plug her up. Should take less then 2 qts.
Old Mar 15, 2008 | 12:00 PM
xtrford's Avatar
xtrford
When you drain it, fab up a splash shield so it doesn't hit the crossmember and make a huge mess on your floor.
Old Mar 15, 2008 | 05:54 PM
steve(ill)'s Avatar
steve(ill)
Mercon or V is acceptable. Factory uses what ever the transmission used. (New is MerconV).
