Keyless Entry Question
Old Mar 15, 2008 | 08:10 AM
birdbrain9291's Avatar
birdbrain9291
I could use a little help with a 2004 F-150 that I purchased at auction, it has the "Keyless entry" drivers door and I would like to erase the present code and put in our own secret number. In the book it states that there is a mnfg. code that is preset and a card in the glove box that has this number. But having bought this vehicle at auction and the previous owner has passed away and I don't have the card to be able to get rid of the present numbers and put ours inplace. Does anyone know if each vehicle has a seperate number from the mnfg. or is there just one number for all pickups for that year? And what it is? Pat. P.
Old Mar 15, 2008 | 08:21 AM
FTE Ken's Avatar
FTE Ken
Moved to proper forum: out of 2009+ F150 to 2004-2008 F150.
Old Mar 15, 2008 | 08:40 AM
VFR_Man's Avatar
VFR_Man
If you do a search, there are quite a few posts about the code being behind the rear seat or something like that too.
Old Mar 15, 2008 | 08:48 AM
maxnoodle's Avatar
maxnoodle
Keypas use with remote start
Ok along these lines, I put a re mote starter in my Lariat 06' SCREW. Before I did, my keypad worked fine. New, if I lock my truck using my keyless FOB, and then later renetr the truck, the horn goes crazy until I press the ublock button on the FOB...anyone have any idea why this is happening. Was the Remote start installed wrong? Also, before installing the remote start, when using the FOB to unlock the truck the headlights and interior lights would come on, now they do not.
It seems installing the remote statr changed a lot of things that used to work. Any comment / advice on the subject??
Much appreciated!
~ t
Old Mar 15, 2008 | 08:52 AM
Twinsdad98's Avatar
Twinsdad98
I would say that yes, the remote starter was installed incorrectly. I have an 04 with remote start and have never had that issue or the light issues. Mine works the same as before. what make of remote is it? I have a ford remote.. Also, search on remote because I've seen some other threads regarding remotes as well, but mostly, people not hooking up the unlock wires..
Old Mar 15, 2008 | 08:54 AM
maxnoodle's Avatar
maxnoodle
Ford installed it, so I assumed they had it put in correctly...not sure of the Brand...QTECH or something, books in the truck...
Old Mar 15, 2008 | 12:45 PM
wolfefx4's Avatar
wolfefx4
Two options...
(1) (try this first!)
If you were sitting in the driver seat, look above where your left toe would be up against the firewall, there is a box look for a 5 digit # Larger than the other #s this is the original entry code.
Use a flashlight!
(2)
The five digit code is on the BSM box which is a black box located on the driver side back wall of the cab. The box will have a blue and green plug to it. Remove the back seat and it is behind the black wool material. You will have to remove a few push pins to pull up the corner. The number is right on the front of box. Every truck should have come with a card with the number on it in the glove box with the key fobs.
Or the dealer can get it for you. Mine was on the back wall. I have an 04 super crew
Old Mar 15, 2008 | 01:46 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
2 choices man
1. pull apart the rear seat and get the code off the module
2. go to dealership and pay about $100 for them to hook up a scanner and read the code out
good luck
Old Mar 15, 2008 | 02:08 PM
fx4local3284's Avatar
fx4local3284
i have an 04 fx4 that i got from auction and the dealer read the code for free. just tell him u need the code and they sould do it.
Old Mar 15, 2008 | 06:56 PM
FTE Trigger's Avatar
FTE Trigger
Welcome to Ford-Truck Enthusiasts! Hopefully this past thread will provide some assistance on helping you to get to you door code...https://www.ford-trucks.com/forums/7...pad-reset.html
