timing chain slack 360?
Old Mar 14, 2008 | 08:29 PM
ramarado's Avatar
ramarado
Question timing chain slack 360?
How much slack is too much for the timing chain. I pulled the dist. cap, turned the motor by hand until the rotor moved, then turned the other way. The dampner will move about 1" at the timing marker b-4 the rotor will move. I had it on 0 deg. then whenever I moved it, 0 was on the other side of the marker, if that helps.
Any thoughts?
Old Mar 15, 2008 | 09:31 AM
Redmanbob's Avatar
Redmanbob
From the sound of it that is fine (rather new)
I usually check it through the fuel pump access for about .5" of slack maybe .75" if it's more than that, best to just getter done so it doesn't get you when you really cant deal with it.. out in BFE
Mikerage
1997 - 2003 F150
30
Jul 29, 2016 02:59 PM
woogy97
2004 - 2008 F150
Feb 28, 2016 04:26 PM
Porpoiseater
Feb 28, 2015 03:58 PM
Sam
May 15, 2011 11:24 AM
ErrorS
Oct 16, 2007 12:41 AM
