Water Pump Replacement Tips?
Old Mar 14, 2008 | 06:56 PM
timsexcursion's Avatar
timsexcursion
My water pump is leaking out the weep hole and needs replacing. I'm looking for input on any who have changed this and any helpful hints. Looks like I should be able to do it without pulling the radiator...just the shroud. I probably should also replace the thermostat. I also am looking for a good place to buy one. I'm assuming the local dealer will be pricey. Thanks.
Old Mar 14, 2008 | 07:01 PM
zx250's Avatar
zx250
Of the next Riffraff East
You can do it either way. I chose to pull the radiator. Only takes a few minutes and gives you a lot more room to work. I went to the local dealer so I don't know about price. It has been a few years so I don't remember a lot.
Old Mar 14, 2008 | 07:53 PM
trike1946's Avatar
trike1946
You will need a tool to take the fan off.
I split the shroud top to bottom on all my trucks. when i put them back I wire tie the top and bottom together. You will have the hoses off, so it is not much to pull the radiator. Flush it out good and add the right coolant.
Old Mar 14, 2008 | 08:00 PM
timsexcursion
Your comment 'add the right coolant' has me wondering...is there a special coolant I need to know about or an additive?
Old Mar 14, 2008 | 09:52 PM
00Dave's Avatar
00Dave
The worst part is getting the fan off. I ended up using a ratchet strap and a pry bar. Once that is loose, gently lay it in the shroud. Remove the degas bottle, Disconnect hoses. Remove the bolts for the fan shroud. The shroud and fan blade need to come out together. Be careful with the fan, the edges are sharp. Remove the CPS sensor connector and lay it out of the way. Remove the bolts from the water pump. Keep track of them as there are different lengths. I pulled the therm. and replaced it and the housing as that is what is recommended. Several people recommend the billet therm housing, but I didn't want to wait for it. Then reassembly is the opposite. I think that is pretty much it as best as I can remember. I might have forgotten something along the way, but I am sure you will know when you get in there. I think you might be able to rent a fan removal tool from some parts stores. That would probably be a good idea because that was the worst part.
Old Mar 14, 2008 | 09:54 PM
00Dave's Avatar
00Dave
By the way, I used Zerex G-05 coolant, but everyone has their own preference. Just be sure to use one rated for our engines. Good luck!
Old Mar 15, 2008 | 04:39 AM
ron's power stroke's Avatar
ron's power stroke
maybe this vid will help you out..
http://www.youtube.com/watch?v=3O0fzkizuI0
Old Mar 15, 2008 | 05:48 AM
Alpine6's Avatar
Alpine6
I'd recommend Dieselsite's billet housing and 203 thermostat. Also, change out your upper hose to a non-through the belt hose (ambulance package hose). Also, get some oring sliding grease for the waterpump .
Old Mar 15, 2008 | 06:45 AM
olreb's Avatar
olreb
I had to replace mine a couple of weeks ago I went with A---Zone $149.99 with lifetime warenty it's made of aluminum like the original. I too use the Zerex G-05 coolant.
The only trouble I had was the fan nut. I never got the tool tried to use vice grips didn't work. I had read on here about useing a air chizel to break it loose didn't want to do it but after a couple of hours trying I decided to do it. As soon as I hit the air the nut backed off just slight marks on the nut.
Old Mar 15, 2008 | 06:59 AM
ron's power stroke
i took one bolt out of the pulley and put in a longer one about 1/2 way (just enouph for the bar to hold onto)..then used that bolt and the pulley to hold a against and with the belt still on..i turned the big nut off..if that didnt work..i was going to temped the strap wrench...
Togglebolt
Feb 18, 2013 06:21 PM
BluePitt
34
Jan 9, 2012 06:52 PM
'88 E-350
Oct 29, 2010 07:46 AM
dyoungen
Jul 27, 2009 08:57 PM
mick460
Sep 2, 2002 09:22 AM
