fuel probs...
Old Mar 14, 2008 | 11:55 AM
Superduty krazy's Avatar
Superduty krazy
fuel probs...
Hey guys i having some problems with my truck here....when you leave a traffic light or a dead stop my truck will accel like crazy till it hits 2200-2300 rpm then all it does is blow black smoke it won't shift until i let of the accelerator... It sort of did this before i installed my dp as you can imagin it is now worse....is it posible that my fuel position on the pedal is messed up, Just looking 4 some sugestion
Old Mar 14, 2008 | 02:31 PM
F350-6's Avatar
F350-6
The first thing to check is the fuel filter. How old is it?
Old Mar 14, 2008 | 02:34 PM
ron's power stroke's Avatar
ron's power stroke
i would need to say look at your IC boots and air filter as well as what Chris said...
Old Mar 14, 2008 | 04:40 PM
Superduty krazy
the filter is only 1 month old....i will check the ic boots
Superduty krazy
the air filter is good too but just the same i got a 6637 coming tomorrow
Old Mar 14, 2008 | 06:20 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
If you have black smoke, it's defanitely not a lack of fuel. Something to do with when it's injected and how much. Im thinking its not something mechanical, more like electronic.
Old Mar 14, 2008 | 06:56 PM
Kwikkordead's Avatar
Kwikkordead
I think it's a boost leak that is popping open under pressure. The MAP is reading boost and the ECU commands fuel, then the boost leaks and you get a bunch of black smoke because of not enough air.
Or it's simply a clogged air filter.
Or a wastegate falling open.
Old Mar 14, 2008 | 07:03 PM
Superduty krazy
thx for the ideas everybody I will post back when i find something out...
Old Mar 14, 2008 | 07:06 PM
Superduty krazy
when i'm checking the wastegate what should i look for???
Old Mar 14, 2008 | 07:17 PM
Kwikkordead
That's really the last thing to suspect here.
The way to check it, however, is to tee a line with the pressure guage the canister and apply gentle shop air pressure to the tee. The WG lever on the top of the exhaust housing should not begin to move until the air pressure on the guage reads 5 psi.
I set mine to 12 so it wouldn't open before that.
Old Mar 14, 2008 | 07:39 PM
Superduty krazy
ok well i will check the boots first, just trying to put a game plan together...I need to get this fixed before I move on to my pump mod...
Old Mar 14, 2008 | 08:04 PM
F350-6's Avatar
F350-6
Thanks Kris. I was on hold with the IH dealer odering fuel filters for some 6.0's when I typed my earlier post. I was thinking air, but I guess I had fuel on the brain.
Old Mar 14, 2008 | 08:24 PM
bdrummonds's Avatar
bdrummonds
It sounds like a line pressure problem in the tranny to me.
Old Mar 14, 2008 | 10:16 PM
Superduty krazy
I had the tranny rebuilt in the fall....I will ask the tech that built it what he thinks ....I will start with the easy things ppl have pointed out to me, thx
Old Mar 15, 2008 | 05:55 PM
Superduty krazy
ok guys this is the part where i feel like like an a fool my air filter was junk...i put 6637 in today and it runs like a green rocket
