360 crankshaft?
I've actually taken these motors apart. They have the SAME BLOCKS, SAME HEADS (FT heads are not easily mistaken for FE heads) SAME EXTERNAL PARTS FOR BOTH. With,( as I said before, the crankshaft and harmonic balancer). Get your head out of those books and get your hand dirty taking these things apart. If you WERE actually a Ford parts man, you apparently weren't very good at it.
You keep throwing parts numbers around, like they're bullets. Your shootin' blanks here.Where else would you find 30 year old parts numbers for 30 year old trucks, from a crystal ball?
If the engines are the same as you say, why would Ford list different blocks and heads?
I never said the FE heads (1973/76 360/390 = D5TZ-6049-H) were same as FT heads (1973/78 330 MD = D6TZ-6049-A). The earlier examples are listed below.
1964/72 Ford Truck Parts Catalog ~ 330/361/391 Engine Section 60.6
C4TZ-6010-L .. Cylinder Block - 330 MD ~ VIN engine codes: A (64/65); C (66/72)
C4TZ-6010-K .. Cylinder Block - 330 HD ~ VIN engine codes: M (64/65); D (66/72)
C4TZ-6049-D .. Cylinder Head - 330 MD
C4TZ-6049-E .. Cylinder Head - 330 HD/361
C8AZ-6049-M .. Cylinder Head - 1968/72 360/390
If the engines are the same, why would Ford have different VIN engine codes? Explain that...if you can.
I was an excellent Ford partsman, and got very well paid for it. If I wasn't disabled, I'd still be working.
Your problem, besides being stubborn
is you were never a Ford partsman.
You don't have any Ford parts books, so who's shooting blanks here Kemosabe?
Uh....who's clueless?
Some of the confusion is obvious if you step back a second.
U-Haul called the 330 it used an "HD" - Ford called it an "MD". Right there, you have half of the current confusion in this thread. The REAL 330HD was an FT with a steel crank. At least, that's what I've gathered from this conversation and others like it, plus my own resources (not very accurate, but interesting none-the-less).
The rest is, I gotta say, a pissing contest.
Back to the 330 and MD vs. HD. I went through my Motor's manual, which in no way is the final word on anything. BUT - I can say, looking at valve specs and such, which heads it may have had on it at certain times, based on valve angles, stem diameters, exhaust manifold torque, etc (FT engines have a much larger exhaust valve stem).
66-77 330MD - FE heads.
65-79 330HD - FT heads. Large exhaust valve stem.
359/389 - FT heads
The 330HD always had a steel crank, the 330MD a cast one - based on the fact that the damper torque spec is higher on the 330HD compared to the 330MD. The HD has the same torque spec as the 361/391, the 330MD the same as all the FE engines. So, this jives.
Even though the 330MD used a cast crank, it still has the same clearances as the steel crank engine, not the FE clearances. Same for 359/389
I can't find much for the 359/389, except that one year they spell out the torque spec for the 389 as the higher torque, so it has a large-nose crank.
Anyway... let's not have this turn into a name-calling contest.
It's very confusing.
This catalog has ALL the FT engines listed: 330 MD-HD-XD & 361/391.
I have three editions (1st, 1981, and last-10/88) of the '73/79 LIGHT truck parts catalog on microfiche, but it only has 330 MD info in it.
I also have the 64/72 catalog where every engine Ford used in those years is listed.
This entire thread is making me sick (and costing me more $$$)!
I'm sorry I ever responded to it!!
I would like to upgrade the engine by swapping it to a FE block. But the more we get into it, the more I figure my FT block is similiar and why not just put a new crank, rods and pistons in there to beef it up.
Art, the 330 MD was availlable to the public to commercial medium duty trucks. The 330 HD and XD is the same engine. Ford called it Heavy Duty HD, U-haul called it Extra Duty XD. The differences between both engines are listed above. The HD/XD is a U-haul exclusive engine. I have sent you the info today via the mail, should get it in a week or two.
Tyl
Paul Newman, Strother Martin and Luke Askew = Cool Hand Luke.
There are two 1940's White dump trucks and an circa 1947 Ford truck is this film, but AFAIK, none had a ___ engine!
There's also that buxom broad washing a 1941 Desoto Coupe. As original, the DeSoto had a 237 cid flathead 6 engine in it.
The old time Ford parts guys here, know this stuff without looking in the books. The stuff you're printing out, can be done by a 12 year old kid. You may have the rest fooled with your stuff, but I had you pegged long ago. Nice try though.
I ordered it via amazon about a month ago. Was thrilled to see they mention the 330 HD on the cover. No sure to what extinct. Hope it's not summarized in one phraze.
Tyl
