wts?
Old Mar 13, 2008 | 09:20 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
wts?
my wait to start light stays on for about 15 to 20 seconds after i turn the key and will not start when its cold if i dont plug it in -is that a gpr problem
Old Mar 13, 2008 | 09:27 PM
884x4broncoII's Avatar
884x4broncoII
could be a glow plug problem, might have a couple dead plugs, try waiting 15-20 seconds after the wts light goes off, anything below like 20 degrees outside i have to wait a little bit after the wts light goes off for it to fire
Old Mar 13, 2008 | 09:34 PM
jimwilsonmasonry
well if i gotta change my glow plugs im gonna do the diy injectors 2
Old Mar 14, 2008 | 08:06 AM
tjbeggs's Avatar
tjbeggs
You can test you GP and relay. For the relay check with the key turned on (us a helper its much easier) make sure you have battery voltage on both larger terminals. A test light or voltmeter work best.
for the GP's read this
http://good-times.webshots.com/album/558822854fIThwz
Old Mar 14, 2008 | 07:51 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
[QUOTE=tjbeggs]You can test you GP and relay. For the relay check with the key turned on (us a helper its much easier) make sure you have battery voltage on both larger terminals. A test light or voltmeter work best.
http://good-times.webshots.com/album/558822854fIThwz[/QUOTE]
That links goes to the turbo.
Old Mar 14, 2008 | 08:46 PM
tjbeggs's Avatar
tjbeggs
OOPS!! I guess I didn't pay that very close attention. here is the right thread
https://www.ford-trucks.com/forums/6...=1#post5286089
