HELP! new engine rattaling
Old Jun 15, 2001 | 05:00 PM
highboy1973's Avatar
highboy1973
i have a 78 bronco with a 351m. i rebult it about a month ago. after the engine warms up enough to open the thurmostat the water pump starts rattaling at idle. i have changed the water pump and it still rattels. i think the water is boiling in the engine around the cylinders because i had them bored. i have tried everything and talked to alot of people about it and they are clueless. if anyone as any idias i would like to hear them
Old Jun 15, 2001 | 07:22 PM
beartracks's Avatar
beartracks
Do you have a good temp gauge. It would have to be very hot or low on water to start getting steam pockets. Are you certain it's the water pump making noise? The head gaskets could be on wrong blocking a passage but I've never heard of this symtom.Can you describe the sound in more detail? Could it be the belts? I almost tore the front of an engine down once after using PEP boys belt dressing. It sounded like a knock! A little water on the belts while it's running, if the sound goes away you found something.
1977 Ford F-100
400m/c6
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Jun 15, 2001 | 07:32 PM
highboy1973
[font size="1" color="#FF0000"]LAST EDITED ON 15-Jun-01 AT 08:32 PM (EST)[/font][p]i sprayed wd40 on the belts and the noise was still there. i drained the water out and ran it for a few seconds with it warm and the noise went away. the temp gage seems to work fine and i have replaced the termostat with a 180 degre one
Old Jun 16, 2001 | 03:08 PM
adobbs's Avatar
adobbs
Dan Drover
Jul 18, 2014 12:18 PM
Dan Drover
Jul 15, 2014 11:55 AM
bnmc98
Mar 20, 2010 09:23 AM
Douglas DC-9
Mar 27, 2009 04:48 PM
azu
1983 - 2012 Ranger & B-Series
Jun 21, 2007 01:13 AM
