Sponsored by: Auxito
Help brake probems i think
Old Mar 13, 2008 | 07:47 PM
firefighter1416's Avatar
firefighter1416
Question Help brake probems i think
ok on my 2000 F 150 ex cab 5.4 4x4 i have a little brake problem, whenever i get the truck up to speeds around 85 or 90 for a period of time say 5 min and hit the brakes suddenly i get a noise similare to that of worn out rotors. The pads and rotors are fine, and it only dose it at these speeds except for Every great once in a while it will do it at normal speed,and I know i don;t need to drive that fast but any way the point is it shouldn;t do this
Old Mar 13, 2008 | 08:59 PM
Club Wagon's Avatar
Club Wagon
Never been aware of any particular noise associated w/"worn out rotors".
Some brake noises are related to sticking calipers or stiff piston seals.
Old Mar 13, 2008 | 09:03 PM
firefighter1416
ok it sounds rough, like worn out pads on rotors
Old Mar 13, 2008 | 09:33 PM
Thudpucker's Avatar
Thudpucker
I would think that noise is the ABS Computer if you have that. It also means you may have air in the Computer module.
Old Mar 13, 2008 | 09:54 PM
firefighter1416
well i don;t think its the abs making noise if thats what you mean because i don;t push the brakes hard enough for them to work but your answer seems to make the most sense so far, how do you get the air out of the module, also i know how to do a lot of work myself but if i did take it to a shop do they have a way to diagnose brake problems
Riskyguy
2004 - 2008 F150
Jul 20, 2014 01:49 PM
Ryan50hrl
2004 - 2008 F150
Aug 14, 2013 05:28 AM
stevie624
Dec 8, 2012 05:37 PM
Enomra
1997 - 2003 F150
Oct 9, 2006 11:38 AM
SubmarineAZ
1978 - 1996 Big Bronco
Sep 22, 2002 07:52 PM
