Sponsored by: Real Truck
Ford accessory parts
Old Mar 13, 2008 | 06:48 PM
abmorejon's Avatar
abmorejon
Unhappy Ford accessory parts
Does anyone know where and If I can find an end cap for my 2006 F250's running board or step bar. This bar is oval, it is chromed, and has an end cap on the back and front part of it (which seals it). I knocked the front drivers side cap off and do not want to purchase a new set of step bars.
any help?
Old Mar 13, 2008 | 06:54 PM
Layson's Avatar
Layson
You could try emailing www.powerstrokeshop.com or www.1stfordparts.com they may have it. But sounds like a tough part to find!
Old Mar 29, 2009 | 07:56 PM
abmorejon's Avatar
abmorejon
Tried online, but had better luck going to a local dealer for the part. quite expensive for a plastic cover though.
Old Mar 29, 2009 | 08:43 PM
husker's Avatar
husker
What year and style will work? I have an extra board from a crew cab in the garage that is going to go to the junk and I could pull it and send it to you if it will work. It may be a little scratched, but is from a 2000 or newer Super Duty. I won't be able to get to it till the end of the week though. I bought the board used a few years back to get the brackets to replace a couple of broken ones.
Old Mar 30, 2009 | 05:47 AM
Furian's Avatar
Furian
You Keep What You Kill
If you have a crew cab, then you may want to purchase these nerf bars... may not be any more than the new end-cap (if you can even purchase it from the dealership).
https://www.ford-trucks.com/classifi...ct/26253/cat/5
