I was wondering if anyone out there has gauge pods on the a pillar, dual or triple? Was thinking about getting some gauges and was wondering what it would look like if anyone has any pics? thanks.
I have been wanting to get gauges too. I wanted to get a tranny temp, oil pressure, and then some other one. Does anybody know where i can get good gauges for a decent price, some of the places i looked are crazy on prices.
cool thanks alot everyone. did you paint the pillar yourself or did it come in black??
It comes black.....I'm going to paint it a semi-gloss black to match the bezel colors in my truck. I used Krylon Fusion for my bezels with great results, the prep is the most important. Use an alcohol pad to to romove any type of grease, prime it with a wet sand, paint in small passes until you get good coverage, and finish with a mild rubbing compound to get rid of any orange peels. Optional is to wet sand again the dryed paint and spray a couple of coats of clear coat.
cool thanks. i was looking to go with the ultra-lite II full swee gauges. i think they will match the stock gauge cluster perfect with the through the needle light. also, i was thinkin trans temp, oil pressire, and either air/fuel ratio or vaccum gauge..
Go to evilbay and search gauge pods.There is 1 or 2 that sells a setup for a little over a $100.3 gauges with a pod
I have seen the triple gauge set up your talking about...but i dont want those gauges. I want a tranny temp, oil pressure, and maybe a engine temp gauge.
150mudder, have you thought about getting a water temp guage too
i knew there was one i forgot. yes i have thought about it but i do have to admit, once you've seen an air/fuel ratio gauge, it looks pretty nice with the bar bouncing back and forth with the push of the pedal, haha.
