Rear view mirror??????
Old Mar 13, 2008 | 07:29 AM
cobra427's Avatar
cobra427
When I bought my 1996 f350 351W 5 speed, the rear view mirror was in the glove box. I bought super glue, cleaned both contact points and held it in place for about 30 seconds. Three weeks later while adjusting mirror it pops off#$%^#$........... What am I doing wrong?.
Old Mar 13, 2008 | 07:49 AM
dan01247's Avatar
dan01247
They make a special glue for rear-view mirrors. It's available at any local auto parts store. I just bought some at Auto-Zone for about $3.50.
Follow the directions, use alcohol, and you should be fine - and don't forget to razor-blade the contact point clean.
Old Mar 13, 2008 | 10:29 AM
dave2's Avatar
dave2
Just get a girlfriend that wears a lot of makeup. she can tell you at a glance what's behind you as she's touching up....
Old Mar 13, 2008 | 02:34 PM
_red rocket_'s Avatar
_red rocket_
Yup...used some 5 months ago and not the slightest hint of a problem. Follow the directions on the package and you sould be good.
Old Mar 13, 2008 | 05:43 PM
quicklook2's Avatar
quicklook2
i use 2 part epoxy and let it set overnight before i put the mirror on.
never had to do it twice.
Old Mar 13, 2008 | 05:51 PM
BChance's Avatar
BChance
If it's behind you, you already passed it, and don't really need to see it again!
Biggest thing is clean surfaces, cobra.. almost any quality cyanacrolyte glue will work, but the easiest/fastest/best way is the rear view adhesive with the primer.
