Aerostar Ford Aerostar
Motor swap q:
Old Mar 13, 2008 | 02:03 AM
DCRB's Avatar
DCRB
Motor swap q:
Are the engines from other years of aero's swapable from one to another.
example: our latest addition to our collection, our 93 xlt de-lux awd has 197,xxx on it. I'd like to go to the j/y, pull a diff. 4.0l out of either another star or and explorer, and rebuild it. but what i'm concerned about is will the wiring harnesess be plug and play? or will i have to remove the wiring harness(s) from the doner car and maff and ecu and what not? and what about things like the fuel rails, exhaust mani's, intake, etc.?
also, is this the same for the 3l's?
thanks soooooooooo much in advance.
p.s. i hope this thread helps others. my idea is that i'd like to have a donor motor already in storage, just needing to be sealed up and put into the car as sort of... insurance if you will.
p.s.s. edit: i got the ebrake light/ rabs light to go out, the reservour was almost bone dry.... oh well. thanks for the tips!
Old Mar 13, 2008 | 10:10 AM
Bear River's Avatar
Bear River
Former ******
Yes, you can use the engines from other models and years. I do know there are subtle differences. Make sure the oil filter is in the same location on your old and new engine (I point this out because the headers made for Explorers and rangers hit the oil filter bracket, which leads me to believe that it is oriented differently on the Ranger/Explorer. I am aware that many explorers and rangers also have an EGR system, whilst Aerostars rarely do. I'm not sure if that would pose any problems, though I'm sure you could swap the related parts to make it work either way. So long as you stick with the 4.0L OHV pushrod engine, you should be fine. The SOHC or DOHC would likely require modification of the engine compartment to work properly, so just make sure that your donor is the older OHV and not the SOHC.
Old Mar 13, 2008 | 11:09 AM
Pablo-UA's Avatar
Pablo-UA
All 3.0 engines are swapable, but if you have FWD donor, use your stock air intake parts and mounting.
Old Mar 13, 2008 | 12:25 PM
Pablo-UA's Avatar
Pablo-UA
DCRB, do you want to swap engine? all cologne engines (2.6, 2.8, 2.9 and 4.0 OHV and 4.0 SOHC) have the same mounts, same bolt pattens but different ECUs and wiering. People say with some modifications 4.0 SOHC fits aero too.
Old Mar 13, 2008 | 12:38 PM
Pablo-UA's Avatar
Pablo-UA
check engine application here.
http://en.wikipedia.org/wiki/Ford_Cologne_V6_engine
Old Mar 13, 2008 | 08:19 PM
bozzzz94's Avatar
bozzzz94
Pablo-UA is right DCRB concerning these engines. Most times your top half of your engine will be recycled/reused for the most part if everything survives not being damaged while removing the hardware so then you would be able to "swap' the items over. This is called a "short block" when just the block is used and all of the top half of the engine like, the intake, heads and the like are reused. It is called a "long block" when evrything including the kitchen sink is retained from the donor vehicle and placed into yoru ride.
Old Mar 13, 2008 | 08:29 PM
93nighthawk's Avatar
93nighthawk
Actually your are mostly correct Bozz, a Long block has everything except the intake and accessories.
A 'Drop in' will have everything including the oil filter (aka kitchen sink)
Old Mar 14, 2008 | 12:39 AM
xlt4wd90's Avatar
xlt4wd90
I thought a short block is just the lower part, with no heads.
Old Mar 14, 2008 | 05:08 AM
Pablo-UA's Avatar
Pablo-UA
somewhere in internet I used to find engine compatibility tables, what parts to change. But ifyou get donor and you have your stock engine you will see what toinstall from your stock engine. Difference ofheag gaskets is not so important. I used to change engine mounts, air intake, intake manifold and exaust manyforlds, PS pump, alternator, A/C compressor (all with stock mounts and brakets).
Yeah, it is 4-6 hour work, with beer - one weekend.
Old Mar 14, 2008 | 06:40 PM
DCRB's Avatar
DCRB
is there anything else to drink that helps motor swaps go smoothly? i still have 3 years to go (and 9 days) till i can buy beer...
Old Mar 14, 2008 | 07:33 PM
bozzzz94's Avatar
bozzzz94
naw-its best to play it safe. If your not of age yet best to play it safe and put a nipple on a bottle of A & W rootbeer. Don't forget. I want you in by 9 and don't forget to brush your teeth either young man.
Old Mar 14, 2008 | 07:34 PM
96_4wdr's Avatar
96_4wdr
join up. the Army will make a man of you and give you all the warm Falstaff 3.2% beer you can drink
but ya can't take yur Aero to Iraq, no armor
Old Feb 10, 2016 | 08:19 PM
Fordboy49's Avatar
Fordboy49
Hello fellow Aeros,
At 248k miles, my '96 AWD engine is showing less power. It has the lifter noise. I still don't use any oil but the kick at take off is somehow weaker by quite a bit. I also have a 1997 AWD which is at 147k miles but has a cracked oil pan. Furthermore, the '96 body is in better shape. So I am just wondering if I can take '97 motor to replace the '96 motor? Can I do the long block swap or just do the short block only? Thanks in advance. Mario
Old Feb 10, 2016 | 09:59 PM
zenish's Avatar
zenish
Rebuilding The Ford 4.0L Pushrod V6, Doug Anderson, Automotive Rebuilder, April 2001
Smb1913
Sep 14, 2017 11:22 PM
myakkacracka
13
Jun 16, 2016 11:33 AM
Flexxj90
6.4L Power Stroke Diesel
Feb 16, 2016 12:23 PM
