Turn signal switch?
Old Mar 12, 2008 | 10:33 PM
Fordworth's Avatar
Fordworth
Turn signal switch?
I searched but didn't find this specific problem. My signals and brake lights each work properly by themselves but the brake lights won't work when a signal is on. This happens on both sides. Could it be anything other than the TS switch?
Old Mar 12, 2008 | 11:10 PM
jcduerr's Avatar
jcduerr
have you checked your grounds and for shorts
Mil1ion's Avatar
Mil1ion
The problem is probably in the TS switch.
Everything runs through it and is the cause of most problems.
Do the indicator lights come on as well when applying the brakes?
Old Mar 12, 2008 | 11:35 PM
whalerron's Avatar
whalerron
Check the wiring at each of the rear taillight assemblies. If you lose a ground back there, it will cause problems like you are seeing. I have had to fix the ground issue at a rear taillight on 3 of my trucks.
Old Mar 13, 2008 | 05:19 AM
Mecinoid's Avatar
Mecinoid
Man, these turn signal switches cause some issues don't they. Well, once you've gone through it you'll realize it's a cheap fix but, it takes some of your time. If a electo-mechanic tech is involved it can be a bit costly. It's best to learn how to fix these issues yourself. You just have to think it through and be patient.
Best of luck.....
Old Mar 13, 2008 | 10:22 AM
Fordworth's Avatar
Fordworth
I did check the grounds and all seems ok. The indicators don't come on when applying the brakes. When I have the brakes on then turn on a signal the other side goes out. I put a test light to the contacts on the TS cam and had power to all 4 with just the brake lights then constant power to the 2 inners while the 2 outers flashed with brake lights and a signal on. Does this sound right? I have a '78 fixed column in the truck.
Old Mar 13, 2008 | 11:31 AM
Mil1ion's Avatar
Mil1ion
This may help you some.
Old Mar 13, 2008 | 09:12 PM
Fordworth's Avatar
Fordworth
I found the problem. Go figure it was the replacement cam I had installed a few months ago with "Made in Taiwan" stamped on it. We all know the moral of the story.
A little brainstorming and tweaking (of the tabs on the cam) seem to have it working.
