High PH in Radiator
Old Mar 12, 2008 | 07:28 PM
kawa's Avatar
kawa
High PH in Radiator
How do I lower the PH level in my cooling system? I am at 11.0 and need to be somewhere around 8.0
Anyone familiar with this area?
The nitrate level is ideal @ 1200 The freeze point is -34* F
Rog
Old Mar 12, 2008 | 08:10 PM
MADVAN's Avatar
MADVAN
Rog
You used tap water? Should have used distilled or demineralized.
8.0 is higher acidity than 11.0.
Ph test is more for long life coolant.(factory gold)
The nappa PH strips are not the correct SCA test for green (low/no silicate) coolant
Fleetguard 3way strip tests for- Freeze,Molybdate,Nitrite. (SCA Test)
Fleetguard Quick-Check strip tests for- PH,Sulfate,Chloride.
Bill
Old Mar 12, 2008 | 08:30 PM
kawa's Avatar
kawa
I did use distilled water, fresh low silicate anti-freeze 50/50, changed all hoses, installed a 203* stat and prayed to the coolant Gods on 10-01-07.
I do have some Napa strips and I checked the coolant today (I just changed water pump and saved the coolant for return) and the PH is 11.0 and the strips bottle says "Immediate attention necessary"
So, how do I get the PH into the 8.0 range???
I realize that SCA is another animal.
Rog
Old Mar 12, 2008 | 08:54 PM
tjbeggs's Avatar
tjbeggs
I don't know! Never found high PH. I use well water in every coolant change/flush I have done (couple hundred!) I will be watching on this one.
Old Mar 12, 2008 | 09:19 PM
MADVAN's Avatar
MADVAN
Its not a fish tank!!!
11.0 is less acidity.
Have heard you can raise the level with distilled vinegar.
Try the google thing.
I would not put it in my cooling system.
Bill
Old Mar 12, 2008 | 09:22 PM
Robbgt's Avatar
Robbgt
Uh oh... no tap water??? ..... After I did backflush, I just left the water that was in the block, drained rad, and filled with coolant (to make 50/50 mix) and added SCA's... woops!
Should I even ask what the tap water is doing???
-Robb
Old Mar 12, 2008 | 09:49 PM
kawa's Avatar
kawa
Bill, that fish tank comment was funny, I'm still chuckling
In my pursuit for information I came across several articals addressing high PH in diesel cooling systems and one of the things that it does is attack solder, aluminum etc, etc. I need to get different test strips to test my SCA which I will do. None of these dang articals would tell me how to change it so I did what I should have done in the beginning is turn to FTE.
If in fact that high PH level does eat away at solder then it needs to be addressed and corrected.
I know one thing for a fact that I got into a hot tub several years back and the PH was so far out of wack I thought that I was going to become a saprano, and they were not soldered on. He he he
Rog
Old Mar 13, 2008 | 08:17 AM
MADVAN's Avatar
MADVAN
Found this hydrochloric acid (pool supply)
I never had to deal with high ph
Seems 7.5 to 11.5 is accepted levels from most motor manufactures.
From what i found the high ph came from the additive package in the brand of coolant.
I would leave it alone the #s will fall with use.
Pool Boy Bill
Old Mar 13, 2008 | 11:28 AM
kawa's Avatar
kawa
Pool Boy, Hmmmmm sounds like you're starting a new career.
I got a suggestion for another forum to pour a cup of vinagar into the system and that would bring it down.
Question: Would I then have a "Pickled Diesel?" or maybe a:
"Deviled Diesel"
Rog
Old Mar 13, 2008 | 01:48 PM
MADVAN's Avatar
MADVAN
"Deviled Diesel"
Rog
I just ground the rad and heater core.
Most of the electrolysis comes from the voltage they will produce due to they are insulated from the truck. They become a little battery!
Bill
Old Mar 13, 2008 | 02:34 PM
Action4478's Avatar
Action4478
Not to mention what it does to your hair.....
Old Mar 13, 2008 | 03:25 PM
kawa's Avatar
kawa
Rick, have you been smokin' that wacky tobacky? What it does to your hair?
Help me out on this one. lol
Old Mar 13, 2008 | 04:53 PM
Action4478's Avatar
Action4478
Paint fumes ....
Old Mar 13, 2008 | 05:00 PM
MADVAN's Avatar
MADVAN
Paint fumes ....
imron
Bill
Old Mar 13, 2008 | 05:51 PM
Action4478's Avatar
Action4478
Originally Posted by MADVAN
imron
Bill
Deltron...
