What part is this ????
Old Mar 12, 2008 | 09:25 PM
  #31
250turbo's Avatar
250turbo
only power you need is glow plugs,starter&fuel solenod
Old Mar 13, 2008 | 02:31 AM
  #32
884x4broncoII's Avatar
884x4broncoII
one thing i noticed is the relay next to your reg, if that is your gpr, the area where it bolts looks coroded, the bolt might need to be removed and cleaned to fresh bear metal, iv had things that looked like that and a large amp draw would break the ground connection and it would need to be cleaned to restore proper grounding.
Old Mar 13, 2008 | 02:34 AM
  #33
884x4broncoII
i should have read the intire thread i guess that was already identifed as the starter soliniod ill retract my statement, defently check all fuses including any under hood fuses, recently when changing my gpr, without disconecting my battery i bumped the hot to the ground and blew an 30 amp underhood fuse resulting in a no start condition exactly like discribed.
Old Mar 13, 2008 | 10:23 PM
  #34
Aberasturi_c's Avatar
Aberasturi_c
I know that the big box has been on ford trucks for a long time. My 75 has one the other thing just behind it is for the starter no floating is attatched to fire wall. The part should only be around $15 If I recall properly. I do know that they go bad. Had an extra in glove box, sorry for the life of me cant remember the name.
Old Mar 13, 2008 | 10:27 PM
  #35
Aberasturi_c
thought that I read the whole thing guess was way wrong, do know only about $15 for that part though
Old Mar 14, 2008 | 08:33 AM
  #36
Darrell Maryland's Avatar
Darrell Maryland
Its Fixed thanks everyone i pulled all the fuses the next morning and they were all good. I switched batts the passenger side sounded weak, remounted the VR and she started right up. Oh its a 92 try to fix her up to pull a 44 ft trailer. here's some pic's
Old Mar 14, 2008 | 04:13 PM
  #37
powerstrokeddiesel's Avatar
powerstrokeddiesel
holy **** that is one good looking 92 model... nice work.. rep points sent..
Old Mar 14, 2008 | 04:22 PM
  #38
nelstone74's Avatar
nelstone74
Do you have the king pin mounted to the truck. I don't think I've seen a set up like that before
Old Mar 14, 2008 | 08:31 PM
  #39
Darrell Maryland
Its called Inverted Fifth wheel it can be switched at anytime. heres a few more pics before and after.
Old Mar 14, 2008 | 10:31 PM
  #40
Mark62's Avatar
Mark62
Dam nice looking truck. Did you do it yourself????
Old Mar 14, 2008 | 11:42 PM
  #41
Darrell Maryland
Yes with the help of some friends on the weekend . I may do my first paint job a friend of mine is wiring his garage for electric. I have some 08 side grill air vents i am going to add to the fenders. I may add the 08 wheel well covers any discount ford dealers on this fourm ?
Old Mar 15, 2008 | 11:55 AM
  #42
nelstone74's Avatar
nelstone74
I figured it would look like that. Is there some advatage to that setup? It makes the truck pretty specialized.
Old Mar 15, 2008 | 11:56 AM
  #43
nelstone74's Avatar
nelstone74
BTW the truck is looking good!
