cv-drive shaft help
My drivers side repair on my boot took, but yet I have a "GRINDING" noise from time to time as I'm in a turning radius. I think I might still have some sand or small gravel in between the knuckles of the joints/universals. A simple flushing and then repack won't suit my mind until I totally replace it. Before I bought my 1994 Eddie Bauer 4.0 extended 4 years ago the previous owner told me that he had just had the drivers side cv joint shaft replaced. Whats weird to me is that the drivers side shaft wears out more often. HUmmmmmm-my feeling is the possiblility of the amount of torque/load from the motor and the amount of power that is being applied on that side of the vehicle. The books show that they are of the same size and are interchangeable.
Most front wheel drive cars have more of an offset since the transverse engine installations are more off to one side making for one side's shaft to be smaller and one longer. I'll bet the longer ones wear out quicker since logic would tell you that anything longer would creat more of a vibration.
I'm going to do some research and find the best one for the most longitivity. Original equipment might not be the best in this case---if it was I wouldn't be typing right now would I?
I was trying to buy one off E-Bay a week ago, but once the bidding reached 50 bucks I was turned off. It was OEM, but I was skeptical of the item (all parts there-sight unseen). I do know that the prices rang from 50 to over 100 bucks. There are reman. ones verse new ones from various companies sooooooo to be continued..........
http://www.cardone.com/English/Club/Select/default.asp
good service for the last 10k
tow with them
you'll like the price at rockauto.com site sponsor
tow with them
I bought them locally at a autoparts place, prob could of got them cheaper online.
Installing manual t-case and auto ore manual hubs may easily sovle this problem. I dont like permanent awd. Of course central diff is not simmetrical (30% torq. to front axe, 70%-to rear) and if you press gas too agressively in skid turn rear axe skids first like on RWD van, but to drive all time awd car/van is not so usualll for me.
