Seems nothing I do changes my MPG. I change my fuel filter at 15K, oil at 5K, air filter more often than it's needed. I can feather the accelerator and stay below 2000 RPM. I calculate my MPG by hand and it nearly matches my overhead computer perfectly. The best I have ever gotten is 16.5. I am open to ANY suggestions as to what to do, check, replace, add etc.
At the risk of getting flamed.... I don't know. How can I find out and I'll post it here.
David
The code will tell you on your driver's door pillar. If not there is a mechanical way to do it, but a PITA to do, but if you don't find it with the code, I'll post how to do it.
Dave, where abouts are you in SC, I bought a house in the Aiken area, will be moving there this fall. The gear ration can also usually be found on a tag on the rear differential bolts, but also by vin number, I had someone on here look mine up for me as well.
Thanks Markadeck,
Give me an idea what to look for on the door pillar sticker and I'll have a look.
I live in Florence, Aiken is a nice area.
I can post my VIN if that will help someone tell me.
David
There's a VIN decoder at the top of this page under articles/specs but it didn't show my rear end. Check the door or look for a tag on the rear end. If that doesn't work it may take someone with dealer access to find it out.
Did the VIN decoder but it showed nothing about the gear ratio.
David
Do you really want to know this tonight? For one thing, with a 4X4 you're talking about a grand to change ratio's anyway. If you relax someone will tell you what the C1 means.
I posted my vin before on here to find mine out, " Rotun " Looked it up by the vin number for me. But he's not on right now. I would assume you'd be looking for 3.73's not 4.10's
