Help With Pushrods
Old Aug 3, 2001 | 10:31 AM
skud's Avatar
skud
Help With Pushrods
Ok, I got my shims, and they did help somewhat, but the valves are opening just a little still... So, I am going to get a set of shorter pushrods. Now, how much shorter can I get?? I Shimmed the rocker arms about 0.030" and still it wasn't enough. So, I was thinking about getting 0.040" shorter rods, and then if I needed to, I could still shim them.. Does this sound good??
Thanks
Riley
Old Aug 3, 2001 | 01:28 PM
beartracks's Avatar
beartracks
Help With Pushrods
Check with Ford or Crane cams on push rod length available. With that much change you need to check your rocker arm geometry. Make sure they don't hit the spring or roll off the valve stem. You want to wind up with about .030 (I think) preload on the lifters.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Aug 3, 2001 | 05:17 PM
danlee's Avatar
danlee
Help With Pushrods
farmerchad
2004 - 2008 F150
Feb 8, 2017 05:56 PM
BaronVonAutomatc
28
Apr 2, 2016 05:16 PM
joneswyatt1996
Feb 13, 2016 09:10 PM
mjr46
16
Dec 15, 2015 08:00 PM
BroncoWY
18
Jan 5, 2007 02:36 PM
