Sponsored by: Auxito
2001f150 supercrew lariat4x4
Old Mar 12, 2008 | 11:58 AM
bigdog22's Avatar
bigdog22
Can someone help me please.....4x4h in front will not go no,when i turn switch on I get "click click" (yes2 )4x4 light stays on,but do not engage.4x4 low does work (rear only).
Old Mar 12, 2008 | 08:52 PM
LxMan1's Avatar
LxMan1
Welcome to the forum.
I would check the vacuum lines up around the two solenoids on the firewall near the battery. These control the front differential. Perhaps one of the hard plastic vacuum lines has broken.
Old Mar 12, 2008 | 09:01 PM
steve(ill)'s Avatar
steve(ill)
put the truck in neutral, or let it roll a couple feet in reverse, then shift back to forward and see if it drop into gear. sometimes the vacuum cylinder pin dont drop in the hole and a little encouragement helps.
