Sponsored by: Auxito
daytime running lights stuck on......
Old Mar 11, 2008 | 06:27 PM
Evan460's Avatar
Evan460
I have a 97 F150 lariat, the daytime running lights wont shut off and the bright indicator in the instrument cluster is on with the ignition in off position and key out! wondering if anyone has any answers to why this is happening? I have disconnected the battery and still does the same thing. Any information would be wonderful thank you!
Old Mar 12, 2008 | 08:05 AM
xtrford's Avatar
xtrford
Could have a bad DRL module. Check under the driver's side wheel well and look at the front of the frame cross-memeber, there should be a wire harness that conects to a little black box .....unplug it and see if that eliminates your light problem.
Old Mar 12, 2008 | 09:16 AM
couleeman's Avatar
couleeman
Is it factory day time running lights or aftermarket? My dads boss had the same issue on a vehicle he brought up from the states and ended up disconecting them.
Old Mar 12, 2008 | 06:22 PM
Evan460's Avatar
Evan460
Thanks for the replies, I have narrowed it down to the DRL module I wasn't sure where it was located though, I have a wiring scematics drawing and found the fuse for the module, if anyone is interested it is fuse #9 in the power distribution box
Old Mar 12, 2008 | 06:24 PM
xtrford's Avatar
xtrford
You can simply unplug it in the location I told you. Very easy to do....I did it myself.
Tugnut
1997 - 2003 F150
Apr 4, 2015 12:26 PM
Quest1
Escape & Escape Hybrid
Sep 26, 2014 09:45 PM
awright48
2009 - 2014 F150
Feb 16, 2014 08:13 PM
Gary599
New Hampshire Chapter
Aug 9, 2012 12:33 PM
jasonlasvegas
Jul 5, 2004 11:29 PM
