Help 351/400 crank
Old Aug 16, 2001 | 11:30 AM
Irondale90's Avatar
Irondale90
Help 351/400 crank
Can the 351M crank be changed out with a 400 without changing the connecting rods? Any help please
Old Aug 16, 2001 | 11:52 AM
beartracks's Avatar
beartracks
Help 351/400 crank
I believe the rods are the same but crank "and" pistons are different.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Aug 16, 2001 | 12:30 PM
Bill_Beyer's Avatar
Bill_Beyer
Help 351/400 crank
Rods are identical but you must use 400 pistons also.
Old Aug 16, 2001 | 03:05 PM
Irondale90's Avatar
Irondale90
Help 351/400 crank
So the 351M pistons are taller, mounted higher or something like that?
Old Aug 16, 2001 | 03:16 PM
Bill_Beyer's Avatar
Bill_Beyer
Help 351/400 crank
Yes they have a taller compression height than the 400 pistons. If you were to try to use them with a 400 crank they would hit the head at TDC.
Old Aug 16, 2001 | 03:29 PM
Irondale90's Avatar
Irondale90
Help 351/400 crank
[font size="1" color="#FF0000"]LAST EDITED ON 16-Aug-01 AT 04:31 PM (EST)[/font][p]So would it be more worth while to convert my 400m or rebuild a 390 FE I have a C-6 to bolt to the 390 but i have to change out the output shaft to convert to four wheel drive.
Old Aug 16, 2001 | 03:53 PM
Bill_Beyer's Avatar
Bill_Beyer
Help 351/400 crank
It would be a whole lot easier and cheaper to convert your 351M to a 400 (no M) since there's no engineering or tranny swapping to do but it's your call. In your case where you have to rebuild an engine anyway and rebuild the tranny I'd stick with the 400...
Old Aug 16, 2001 | 07:20 PM
bubbaf250's Avatar
bubbaf250
Help 351/400 crank
RangerHaywood
15
Jul 5, 2010 10:14 PM
78MeanGreenBronco
24
Nov 23, 2008 06:28 AM
cruz76
Mar 26, 2006 05:40 PM
jesse460
22
Jul 9, 2003 07:18 PM
78f250lj
18
Feb 19, 2003 09:34 AM
