ok... i have a 1994 truck with a 1992 motor swapped in. I know it is running very rich but i do not know where the o2 sensor plugs in. i need help with what ever else will help the motor out. it also seems to fall on itself when giving it some gas in 2nd gear.
when under the truck on the side of the exhaust exit you should be able to reach up about 10 inches forward of the O2 sensor and it should be tucked up in there. I can't remember exactly what it is tucked in between.
Did you remove the original one?
