Another dumb question ...
Old Mar 11, 2008 | 08:00 PM
magusjinx's Avatar
magusjinx
I was looking under the hood of my '86 f250 6.9l and am wondering if the "doohicky" mounted under the alternator and powered by a belt from the pulley on the alternator is a type of vacuum pump and if so, what is it for ?
Old Mar 11, 2008 | 08:14 PM
catfish101's Avatar
catfish101
It is a vacuum pump for your brake booster and your HVAC. Diesels don't intake restrict air like a gas motor does so you can't build a vacuum from the engine when it idles.
Old Mar 13, 2008 | 05:59 PM
magusjinx's Avatar
magusjinx
So I guess that means I have to keep it ... I wonder if I can put an electric motor on it and move it to the side ... Is it rpm sensative? Or can it run at a constant rpm and still do its job?
Old Mar 13, 2008 | 06:29 PM
PLC7.3's Avatar
PLC7.3
If you can find the parts........
http://www.california.com/~eagle/figs/vacpump/vac.html
Old Mar 14, 2008 | 04:52 PM
magusjinx's Avatar
magusjinx
Sweet ... Tanx plc7.3 ... Looks like another trip across the state line to the wrecking yard ...
GetSmoke
Oct 22, 2014 02:02 PM
CuMinR
6.7L Power Stroke Diesel
Jun 25, 2013 02:05 PM
f250meangreen
Nov 22, 2009 04:45 PM
bigsky22
Jun 30, 2009 07:28 AM
