Have a 2000 F250 4x4 sc V10, Installing a Kenwood Navigation and it is call for a speed senser and a reverse senser.
The VSS signal is available at the Central Junction Box on a GRAY/BLACK wire (C242b pins 14, 21, 22) and on C240 (pin 18 to the GEM).
The reverse signal will have to be picked up under the hood at the trailer relay block. Look for a BLACK/PINK wire that feeds the backup lamp relay coil. The signal will be battery voltage while in REVERSE.
